Use a small, pointed metal spudger to release the plastic tabs connecting the faceplate to the bottom of the speaker.
A small cable connects the faceplate to the device. Carefully disconnect the cable before fully opening the device.
Slowly flip the device open like a clam shell.
There are several wires soldered to the motherboard that prevent the faceplate from detaching completely.
Peel off the white adhesive to desolder the connections underneath.
Desolder the wires connected to the motherboard.
You can find soldering tips in the How To Solder and Desolder Connections guide.
Keep track of where the wires are connected. When re-assembling you will have to connect the wires in the correct spot.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
