メインコンテンツにスキップ
Jabra Speak 510 Motherboard Replacement
必要な工具と部品
  1. Jabra Speak 510 Motherboard Replacement, Outer Casing: 手順 1、 2の画像 1 Jabra Speak 510 Motherboard Replacement, Outer Casing: 手順 1、 2の画像 2
    • Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
  2. Jabra Speak 510 Motherboard Replacement: 手順 2、 1の画像 1
    • Remove the six 20 mm T6 screws from the bottom of the device.
  3. Jabra Speak 510 Motherboard Replacement: 手順 3、 2の画像 1 Jabra Speak 510 Motherboard Replacement: 手順 3、 2の画像 2
    • Remove the back plate and the grey foam underneath.
  4. Jabra Speak 510 Motherboard Replacement: 手順 4、 3の画像 1 Jabra Speak 510 Motherboard Replacement: 手順 4、 3の画像 2 Jabra Speak 510 Motherboard Replacement: 手順 4、 3の画像 3
    • Use a small, pointed metal spudger to release the plastic tabs connecting the faceplate to the bottom of the speaker.
    • A small cable connects the faceplate to the device. Carefully disconnect the cable before fully opening the device.
    • Slowly flip the device open like a clam shell.
    • There are several wires soldered to the motherboard that prevent the faceplate from detaching completely.
  5. Jabra Speak 510 Motherboard Replacement, Motherboard: 手順 5、 2の画像 1 Jabra Speak 510 Motherboard Replacement, Motherboard: 手順 5、 2の画像 2
    • Using the T6 Torx Screwdriver, remove the four (4mm) screws.
  6. Jabra Speak 510 Motherboard Replacement: 手順 6、 1の画像 1
    • After removing the screws, take out the center covering to free the motherboard by lifting the tabs and pulling it off.
  7. Jabra Speak 510 Motherboard Replacement: 手順 7、 2の画像 1 Jabra Speak 510 Motherboard Replacement: 手順 7、 2の画像 2
    • Peel off the white adhesive to desolder the connections underneath.
    • Desolder the wires connected to the motherboard.
    • You can find soldering tips in the How To Solder and Desolder Connections guide.
    • Keep track of where the wires are connected. When re-assembling you will have to connect the wires in the correct spot.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jordan Murphy
メンバー登録日: 02/16/16
717 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 2-3, Harley Spring 2016 IUPUI, Team 2-3, Harley Spring 2016人のメンバー
IUPUI-HARLEY-S16S2G3
4 メンバー
8のガイドは作成済み
3 件のコメント
Great walk-through... thanks
Walaa Maher - 返信
Be very careful when desoldering the connector cables! The soldering lugs are poor quality and tend to tear off the PCB
Thomas Sprenger - 返信
Hello
Where I can buy the motherboard replacement?
Regards
Lobo Gris - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 17
過去 30 日: 76
今までの合計 7,625
