メインコンテンツにスキップ
Jabra CRUISER2 Speaker Replacement
必要な工具と部品
  1. Jabra CRUISER2 Speaker Replacement, Front Plate: 手順 1、 1の画像 1
    • Use the iOpener tool to unglue the adhesive of the device. The link to the iOpener instructions are listed below.
    • iOpenerの使用方法
  2. Jabra CRUISER2 Speaker Replacement: 手順 2、 1の画像 1
    • Place the flat head of the bigger plastic opening tool in between the front plate and back plate.
    • Pull the tool toward the back of the device to pry it open.
    • Repeat this process over all edges of the device.
  3. Jabra CRUISER2 Speaker Replacement: 手順 3、 1の画像 1
    • Open up the device by pulling the front plate straight up from the back plate.
  4. Jabra CRUISER2 Speaker Replacement, Speaker: 手順 4、 2の画像 1 Jabra CRUISER2 Speaker Replacement, Speaker: 手順 4、 2の画像 2
    • Carefully unplug the red and black wires that run from the speaker to the motherboard by detaching the white connecting piece.
  5. Jabra CRUISER2 Speaker Replacement: 手順 5、 1の画像 1
    • Using the PH000, unscrew the two 5.5mm screws attaching the speaker to the front plate.
    • The screwdriver sizes are located on the sides of their heads.
  6. Jabra CRUISER2 Speaker Replacement: 手順 6、 1の画像 1
    • Gently pull the black and red wires away from the back plate to remove the speaker.
  7. Jabra CRUISER2 Speaker Replacement: 手順 7、 2の画像 1 Jabra CRUISER2 Speaker Replacement: 手順 7、 2の画像 2
    • Carefully pull the wires away from the speaker, detaching them from the adhesive, while keeping the ends intact.
終わりに
作成者
3人の作成者と共同で作成されました。
Spartacus
メンバー登録日: 10/17/14
636 ポイント
5のガイドは作成済み
チーム
Baylor, Team 8-13, Williams Fall 2014 Baylor, Team 8-13, Williams Fall 2014人のメンバー
BU-WILLIAMS-F14S8G13
3 メンバー
5のガイドは作成済み
5 件のコメント
Is this a fairly standard speaker? With radio shack dead, can you suggest a source? Any specs? Yhanks
Brucereno2 - 返信
Did you ever find a speaker for your jabra cruiser?
Scot Tetreault -
halo
where i can get the new speaker for jabra cruiser 2?
Frantisek Fridrich - 返信
simple speaker in electronic parts shop 8ohm diameter 35mm price 1.2 €
A 36 mm speaker will also fit nicely. A 1 watt 8 ohms speaker is the best choice - the amplifier is not able to output enough power to drive a 2+ watt speaker.
Mobi - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 1,785
