メインコンテンツにスキップ
JBL On Stage II Auxiliary Jack Replacement
必要な工具と部品
  1. JBL On Stage II Auxiliary Jack Replacement, Cracking the Case: 手順 1、 1の画像 1
    • Turn the device upside down so that the three rubber pads are facing up.
  2. JBL On Stage II Auxiliary Jack Replacement: 手順 2、 1の画像 1
    • Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
  3. JBL On Stage II Auxiliary Jack Replacement: 手順 3、 1の画像 1
    • Remove the heated rubber pad with a plastic opening tool.
    • Repeat steps 2 and 3 for the two remaining rubber pads.
  4. JBL On Stage II Auxiliary Jack Replacement: 手順 4、 2の画像 1 JBL On Stage II Auxiliary Jack Replacement: 手順 4、 2の画像 2
    • Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
  5. JBL On Stage II Auxiliary Jack Replacement: 手順 5、 3の画像 1 JBL On Stage II Auxiliary Jack Replacement: 手順 5、 3の画像 2 JBL On Stage II Auxiliary Jack Replacement: 手順 5、 3の画像 3
    • Open the device along its seam.
    • Be careful when separating the device because there are wires connecting the two seperate halves.
  6. JBL On Stage II Auxiliary Jack Replacement: 手順 6、 1の画像 1
    • Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
  7. JBL On Stage II Auxiliary Jack Replacement: 手順 7、 2の画像 1 JBL On Stage II Auxiliary Jack Replacement: 手順 7、 2の画像 2
    • Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
  8. JBL On Stage II Auxiliary Jack Replacement, Circuit Board: 手順 8、 2の画像 1 JBL On Stage II Auxiliary Jack Replacement, Circuit Board: 手順 8、 2の画像 2
    • Remove the three 1 cm T-10 Torx screws.
  9. JBL On Stage II Auxiliary Jack Replacement: 手順 9、 1の画像 1
    • Carefully press out the white base tube and push up on the circuit board.
    • Note that there is a small wire connecting the circuit board to the base.
  10. JBL On Stage II Auxiliary Jack Replacement: 手順 10、 2の画像 1 JBL On Stage II Auxiliary Jack Replacement: 手順 10、 2の画像 2
    • Pull the white wire out of the hot glue.
  11. JBL On Stage II Auxiliary Jack Replacement: 手順 11、 3の画像 1 JBL On Stage II Auxiliary Jack Replacement: 手順 11、 3の画像 2 JBL On Stage II Auxiliary Jack Replacement: 手順 11、 3の画像 3
    • Unbolt the heatsink with a 5.5-mm socket and a Phillips PH1 screwdriver.
    • Remove the heat sink; it should detach from the bottom of the device.
  12. JBL On Stage II Auxiliary Jack Replacement: 手順 12、 3の画像 1 JBL On Stage II Auxiliary Jack Replacement: 手順 12、 3の画像 2 JBL On Stage II Auxiliary Jack Replacement: 手順 12、 3の画像 3
    • Remove the T-10 torx screw on the bottom of the device that attaches the base tube to the circuit board.
    • Turn the device so that the base tube is on top.
    • Remove the base tube by pulling up.
    • May need to cut the rubber adhesive between the base tube to the circuit board.
  13. JBL On Stage II Auxiliary Jack Replacement, Auxiliary Jack: 手順 13、 3の画像 1 JBL On Stage II Auxiliary Jack Replacement, Auxiliary Jack: 手順 13、 3の画像 2 JBL On Stage II Auxiliary Jack Replacement, Auxiliary Jack: 手順 13、 3の画像 3
    この手順で使用する道具:
    Desoldering Pump
    $3.99
    購入する
    • Turn the device upside down.
    • Desolder the back lead for the auxiliary port that is circled.
    • Heat the lead until the solder melts.
    • Remove the solder with the solder pump.
    • For help with soldering view the iFixit soldering guide
  14. JBL On Stage II Auxiliary Jack Replacement: 手順 14、 1の画像 1
    • Repeat step 13 for the other two leads.
  15. JBL On Stage II Auxiliary Jack Replacement: 手順 15、 1の画像 1
    • Turn your device right-side up.
    • Remove the auxiliary jack.
終わりに
To reassemble your device, replace the auxiliary jack with a new one soldering it in place. Follow these instructions in reverse order.
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Jared Everingham
メンバー登録日: 01/23/14
368 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 9-28, Maness Winter 2014 Cal Poly, Team 9-28, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S9G28
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,637
