はじめに
This guide will walk you through from taking apart the device, disconnecting all the cables inside and taking out the I/O board in order to replace the auxiliary port.
必要な工具と部品
Begin by removing the rubber caps on both sides of the JBL Flip 2 by using the black spudger to get in between the creases.
Using the classic spudger, get underneath the black tape strips found on both side of the device.
After lifting a portion of the tape off of the device, gently peel the tape off of the device, making sure to keep it intact.
There is another piece of tape on the side of the device with the control buttons. Lift the tape with the classic spudger and then peel the rest of the tape off.
Remove the one 7.0 mm Phillips #1 screw that connects the I/O board to the casing.
ある他の人がこのガイドを完成しました。
2 件のコメント
Is It hard to repair ? I have one that is not charging, I don't know if is the battery or the usb port.
Where can I purchase the auxiliary port (preferably in Europe)?
