はじめに
JBL Clip Plusのバッテリーは充電式です。バッテリーが機能しない場合、デバイスが以前のように長く作動しないか、まったく電源が入らないことに気がつくでしょう。この場合、バッテリーを交換する必要があります。本体を解体して取り外して交換します。
必要な工具と部品
はんだを除去するため必要な箇所は3箇所です。
はんだ付けのヘルプが必要な場合は、「はんだ付けとはんだ除去の接続方法」のガイドを参照してください。これらを取り外すと、バッテリーが外れます。
Its easy to cut wires then connect new battery using solderless connectors.
このデバイスを再組み立てするには、インストラクションを逆の順番に従って作業を進めてください。
15 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
16 件のコメント
Is it possible if replaced with a battery from cellphones with higher AmH rating?
Unfortunately, it would be hard to find a cell battery this small. The original battery is 2" x 1 1/8" x 1/8". My samsung S3 battery is 2 1/2" x 2" x 3/16", so is far from fitting. If you were ok with shaving the molded battery holder down, you could probably fit one that's 2" x 1 1/2" x 1/4" or so (the thickness tolerance is hard to tell), but it would be a lot of work. I think I might just buy a speaker that has good battery reputation (i.e., NOT JBL).
man need to replace the speaker were can i buy just that?
ruitherock - 返信
I think Id rather just buy a different speaker.
The battery model number is P453048D 01.
3.7V
600 mAh
2.22Wh Lithium Polymer
where can I find this batterie
2" x 1 1/8" x 1/8 = 58mmx29mmx3.2mm
on eBay search for li-ion 3.7v 600mah battery cell (optionally add gps if too many obviously wrong batteries).
Then click on entries until you find something the right size (or smaller). The thickness can probably be 4mm +/-0.5mm with no problem. I wouldn't exceed the other dimensions.
You can probably find a 800mah battery within these dimensions if you want to extend the running time.
Costs range a lot. Ordering from China expect to pay 3.70 to 7.00 pounds, including postage. This takes 2-6 weeks, usually 2-3.
3.7V
600 mAh
Is there any supplier in Nepal for the above modeled battery?
Where I can buy the housing for my speaker
Where I can buy the housing for my speaker JBL Clip 1
I’ve just used this guide to remove the battery from my JBL Clip I and the specs on the label are:
Model: P453048D 01
Nominal voltage: 3.7v
Nomina capacity: 600mAh
I haven’t been able to find another 600mAh version and I suspect that was only used in the first model and the Clip II appears to have an 800mAh version of the same battery, which I’ve just ordered online from AliExpress for just over €14. (See all their search results for this battery here) I’m assuming it should work fine and each charge should last longer too due to the extra 200mAh.
Orders usually take a few weeks to arrive to Europe with AliExpress, but when it gets here I’ll see if I can solder it in, seal the speaker back up and will post the results on here…
So did the clip 2 battery work?
D moggey -
