メインコンテンツにスキップ
JBL Charge 5 Buttons Replacement
必要な工具と部品
  1. JBL Charge 5 Buttons Replacement, Fabric Case: 手順 1、 3の画像 1 JBL Charge 5 Buttons Replacement, Fabric Case: 手順 1、 3の画像 2 JBL Charge 5 Buttons Replacement, Fabric Case: 手順 1、 3の画像 3
    • Ensure that the device is fully powered off and no cables are attached before proceeding with the repair.
    • This fabric cover is secured with plastic clips only. Depending on the model, the cover may be secured by both plastic clips and screws.
    • Insert the flat end of the Jimmy into the seam located between the fabric cover on the right side of the seam.
    • Pry upward on the fabric cover to release plastic clips on the right side of the seam.
  2. JBL Charge 5 Buttons Replacement: 手順 2、 3の画像 1 JBL Charge 5 Buttons Replacement: 手順 2、 3の画像 2 JBL Charge 5 Buttons Replacement: 手順 2、 3の画像 3
    • Insert the flat end of the Jimmy into the seam between the fabric cover at the center of the seam and the left side of the seam.
    • Use the Jimmy to pry open the edge with the rubber texture, releasing the remaining plastic clips.
  3. JBL Charge 5 Buttons Replacement: 手順 3、 3の画像 1 JBL Charge 5 Buttons Replacement: 手順 3、 3の画像 2 JBL Charge 5 Buttons Replacement: 手順 3、 3の画像 3
    • Use your hands to gently open the two halves of the casing and slide the fabric cover off of the interior housing.
  4. JBL Charge 5 Buttons Replacement, Buttons: 手順 4、 2の画像 1 JBL Charge 5 Buttons Replacement, Buttons: 手順 4、 2の画像 2
    • Use an iFixit opening tool, to softly pry open each side of the button cover.
    • By removing the rubber button cover, the adhesives will break. This may cause the device to lose its waterproof feature.
  5. JBL Charge 5 Buttons Replacement: 手順 5、 3の画像 1 JBL Charge 5 Buttons Replacement: 手順 5、 3の画像 2 JBL Charge 5 Buttons Replacement: 手順 5、 3の画像 3
    • Use a plastic spudger, and softly pry up on the sides of the button control board to remove it from the slot.
    • Be cautious and don't pull the board all of the way out. The board is connected to the device by a ribbon cable.
  6. JBL Charge 5 Buttons Replacement: 手順 6、 3の画像 1 JBL Charge 5 Buttons Replacement: 手順 6、 3の画像 2 JBL Charge 5 Buttons Replacement: 手順 6、 3の画像 3
    • Pinch the no-fuss ribbon cable connector, and gently pull the cable out to disconnect it from the board.
    • Remove the button board.
終わりに
作成者
2人の作成者と共同で作成されました。
Kat Whaley
メンバー登録日: 09/13/23
753 ポイント
6のガイドは作成済み
チーム
Western Carolina University, Team 1-2, Virtue Fall 2023 Western Carolina University, Team 1-2, Virtue Fall 2023人のメンバー
WCU-VIRTUE-F23S1G2
5 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 41
今までの合計 291
