メインコンテンツにスキップ
Instant Pot 60 EPC Circuit Board Replacement
必要な工具と部品
  1. Instant Pot 60 EPC Circuit Board Replacement, Circuit Board: 手順 1、 3の画像 1 Instant Pot 60 EPC Circuit Board Replacement, Circuit Board: 手順 1、 3の画像 2 Instant Pot 60 EPC Circuit Board Replacement, Circuit Board: 手順 1、 3の画像 3
    • Ensure the device is unplugged and cool before beginning.
    • Remove the lid and inner pot from the Instant Pot and turn the body upside down.
    • Remove the single Torx screw.
  2. Instant Pot 60 EPC Circuit Board Replacement: 手順 2、 2の画像 1 Instant Pot 60 EPC Circuit Board Replacement: 手順 2、 2の画像 2
    • Turn the bottom face counterclockwise and remove it.
  3. Instant Pot 60 EPC Circuit Board Replacement: 手順 3、 3の画像 1 Instant Pot 60 EPC Circuit Board Replacement: 手順 3、 3の画像 2 Instant Pot 60 EPC Circuit Board Replacement: 手順 3、 3の画像 3
    • In order to reach the circuit board you'll need to remove the secondary frame surrounding it.
    • Remove the three Phillips screws securing the frame.
    • Lift the frame, twist and set next to the body. Take care not to damage any of the attached wiring.
  4. Instant Pot 60 EPC Circuit Board Replacement: 手順 4、 3の画像 1 Instant Pot 60 EPC Circuit Board Replacement: 手順 4、 3の画像 2 Instant Pot 60 EPC Circuit Board Replacement: 手順 4、 3の画像 3
    • Depress the latch securing the red connector and disconnect it.
    • Repeat the previous bullet for the white and black connectors.
    • It can be helpful to gently rock them back and forth while pulling up.
  5. Instant Pot 60 EPC Circuit Board Replacement: 手順 5、 2の画像 1 Instant Pot 60 EPC Circuit Board Replacement: 手順 5、 2の画像 2
    • Use a Phillips screwdriver to remove the two screws holding each of the two leads in place.
  6. Instant Pot 60 EPC Circuit Board Replacement: 手順 6、 2の画像 1 Instant Pot 60 EPC Circuit Board Replacement: 手順 6、 2の画像 2
    • Gently walk the 8x1 pin connector out of its socket.
    • It may be helpful to also rock the plug side to side while pulling up.
  7. Instant Pot 60 EPC Circuit Board Replacement: 手順 7、 3の画像 1 Instant Pot 60 EPC Circuit Board Replacement: 手順 7、 3の画像 2 Instant Pot 60 EPC Circuit Board Replacement: 手順 7、 3の画像 3
    • Slide the blue sheathing up to expose the small hole in the lead.
    • Place a SIM card punch into the hole to unsecure the leads and pull them up. If a SIM card punch is not available, then a paperclip or earring should suffice.
    • Repeat for the other two leads.
  8. Instant Pot 60 EPC Circuit Board Replacement: 手順 8、 2の画像 1 Instant Pot 60 EPC Circuit Board Replacement: 手順 8、 2の画像 2
    • Pull the board up slightly to unclip it from its stand and lift from the body to remove the circuit board.
  9. Instant Pot 60 EPC Circuit Board Replacement: 手順 9、 1の画像 1
    • Instant Pot does not provide a new sensor with the device, so it will have to be purchased from a secondary source.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Bela Hernandez
メンバー登録日: 08/28/24
998 ポイント
5のガイドは作成済み
チーム
University of North Texas, Team 6-4, Kilpatrick Fall 2024 University of North Texas, Team 6-4, Kilpatrick Fall 2024人のメンバー
UNT-KILPATRICK-F24S6G4
4 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 19
過去 30 日: 85
今までの合計 707
