メインコンテンツにスキップ
Insignia NS-CLLT01 Button Replacement
必要な工具と部品
  1. Insignia NS-CLLT01 Button Replacement, Insignia NS-CLLT01 Top Casing Removal: 手順 1、 2の画像 1 Insignia NS-CLLT01 Button Replacement, Insignia NS-CLLT01 Top Casing Removal: 手順 1、 2の画像 2
    • Lift the four adhesive covers on each of the corners on the bottom of the clock using a plastic opening tool or your fingernail.
  2. Insignia NS-CLLT01 Button Replacement: 手順 2、 3の画像 1 Insignia NS-CLLT01 Button Replacement: 手順 2、 3の画像 2 Insignia NS-CLLT01 Button Replacement: 手順 2、 3の画像 3
    • On the bottom of the clock, use your fingernail to push the battery cover to the right.
    • Lift the battery cover up and to the right to reveal the batteries.
  3. Insignia NS-CLLT01 Button Replacement: 手順 3、 1の画像 1
    • Remove the two AA batteries by pressing the end opposite of the spring towards that spring and lifting up.
    • Once the batteries are removed, close the cover.
  4. Insignia NS-CLLT01 Button Replacement: 手順 4、 1の画像 1
    • Use a long Phillips #2 screwdriver to unscrew all six 10mm Phillips screws inside the bottom of the clock.
    • Turn over the device to allow the screws to fall out, being careful to catch them so that you do not lose any.
    • The screws may not come out of the bottom of the clock. As long as you have unscrewed them, the clock can still be opened.
  5. Insignia NS-CLLT01 Button Replacement: 手順 5、 3の画像 1 Insignia NS-CLLT01 Button Replacement: 手順 5、 3の画像 2 Insignia NS-CLLT01 Button Replacement: 手順 5、 3の画像 3
    • Turn the clock back over.
    • Lift the top off of the clock by gripping the back of the iPhone dock and pulling straight up.
  6. Insignia NS-CLLT01 Button Replacement, Button: 手順 6、 1の画像 1
    • Using the Phillips #2 screwdriver, unscrew the seven 6mm Phillips screws on the circuit board that is attached to the top of the case.
  7. Insignia NS-CLLT01 Button Replacement: 手順 7、 1の画像 1
    • Lift the circuit board from the device.
  8. Insignia NS-CLLT01 Button Replacement: 手順 8、 2の画像 1 Insignia NS-CLLT01 Button Replacement: 手順 8、 2の画像 2
    この手順で使用する道具:
    • Detach the circuit board from the rest of the clock by gripping the sides of the white ribbon cable connector on the left-hand side of the board and pulling it straight off. You may need to use tweezers to grip the connector.
  9. Insignia NS-CLLT01 Button Replacement: 手順 9、 3の画像 1 Insignia NS-CLLT01 Button Replacement: 手順 9、 3の画像 2 Insignia NS-CLLT01 Button Replacement: 手順 9、 3の画像 3
    • Use this soldering guide to remove and replace any buttons that were not working.
    • The buttons will be labeled on the top of the circuit board, and you will be working with the corresponding connections on the back.
終わりに
作成者
5人の作成者と共同で作成されました。
Preston Jackson
メンバー登録日: 09/23/15
201 ポイント
2のガイドは作成済み
チーム
Baylor, Team 6-9, Williams Fall 2015 Baylor, Team 6-9, Williams Fall 2015人のメンバー
BU-WILLIAMS-F15S6G9
3 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 10
今までの合計 441
