メインコンテンツにスキップ
Insignia Flex 10.1 NS-P16AT10 Screen Replacement
必要な工具と部品
  1. Insignia Flex 10.1 NS-P16AT10 Screen Replacement, Screen: 手順 1、 2の画像 1 Insignia Flex 10.1 NS-P16AT10 Screen Replacement, Screen: 手順 1、 2の画像 2
    • Make sure your device is off and not connected to any power sources to avoid injury
    • Use a plastic opening tool to remove the rear panel from the front case.
    • Insert the plastic opening tool between the front case and rear panel. Use a prying motion to lift the front case from the rear panel.
    • Work the tool around the perimeter of the device until the front and rear panels become separate.
    • The volume rocker and power button will become free from the device when the front and rear panels are separated from each other. Do not worry. These pieces are easily put back into place when reassembling the tablet.
  2. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 2、 2の画像 1 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 2、 2の画像 2
    • Use a Phillips head #00 screw driver to remove the thirteen screws.
  3. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 3、 2の画像 1 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use tweezers to remove the gray pieces located around the speakers and four screws that were removed in the previous step.
    • There should be six grey pieces total.
  4. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 4、 2の画像 1 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 4、 2の画像 2
    • Use a plastic opening tool to flip up the ribbon cable connector that connects the camera to the motherboard.
  5. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 5、 1の画像 1
    • Gently lift the camera lens up from the front case.
  6. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 6、 2の画像 1 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 6、 2の画像 2
    • Use a plastic opening tool to flip the ribbon connector up in order to free the ribbon cable from the motherboard.
  7. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 7、 2の画像 1 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 7、 2の画像 2
    • Free the battery from the motherboard by desoldering the red, white, and black connections one by one.
    • For soldering instructions, visit this guide.
    • Remove the soldering tip immediately once the wire has become free. Too much heat can damage the motherboard.
  8. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 8、 1の画像 1
    • Peel the black tape up that is attached to the battery and front case.
  9. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 9、 3の画像 1 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 9、 3の画像 2 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 9、 3の画像 3
    • Use a plastic opening tool or spudger to remove the battery from the front case.
    • Place the plastic opening tool between the battery and front case. Work the tool around the perimeter of the battery until the battery is free.
    • Do not bend or puncture the battery, or the battery will leak.
  10. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 10、 2の画像 1 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 10、 2の画像 2
    • Use tweezers to free the twisted, red and black wire from the three clips on the front case.
  11. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 11、 3の画像 1 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 11、 3の画像 2 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 11、 3の画像 3
    • Remove the speakers from the tablet by gently pulling the yellow tape up from the front case.
  12. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 12、 2の画像 1 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 12、 2の画像 2
    • Use a plastic opening tool to flip up the ribbon cable connectors that connect the touch digitizer to the motherboard.
  13. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 13、 3の画像 1 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 13、 3の画像 2 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 13、 3の画像 3
    • Gently lift the gray mesh tape up that holds the motherboard down to the front case.
    • Lift the motherboard up from the front case.
    • The speakers are directly connected to the motherboard and will come up with the motherboard.
  14. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 14、 1の画像 1
    • Peel away the grey mesh tape that holds down the touch digitizer's ribbon cable to the front case.
  15. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 15、 2の画像 1 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 15、 2の画像 2
    • Use a plastic opening tool to separate the front case from the LCD screen.
    • Insert the plastic opening tool between the front case and rear LCD screen. Use a prying motion to lift the LCD screen from the front case.
  16. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 16、 2の画像 1 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 16、 2の画像 2
    • Use a plastic opening tool to flip up the last ribbon cable on the screen.
    • Free the ribbon cable from the LCD screen.
  17. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 17、 2の画像 1 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: 手順 17、 2の画像 2
    • The screen is now free and ready to be replaced.
終わりに
作成者
2人の作成者と共同で作成されました。
Morgan Kidd
メンバー登録日: 10/10/16
419 ポイント
3のガイドは作成済み
チーム
Texas Tech, Team 12-3, Bennett Fall 2016 Texas Tech, Team 12-3, Bennett Fall 2016人のメンバー
TTU-BENNETT-F16S12G3
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 9
今までの合計 694
