はじめに
If your Insignia flex 10.1 NS-P16AT10 will not power on, you may need to replace your battery.
必要な工具と部品
Use a plastic opening tool to remove the rear panel from the front case.
Insert the plastic opening tool between the front case and rear panel. Use a prying motion to lift the front case from the rear panel.
Work the tool around the perimeter of the device until the front and rear panels become separate.
もう少しです!
終わりに
