メインコンテンツにスキップ
Insignia Flex 10.1 NS-P10A6100 Screen Replacement
必要な工具と部品
  1. Insignia Flex 10.1 NS-P10A6100 Screen Replacement, Back Case: 手順 1、 1の画像 1
    • Make sure your tablet is turned off and not connected to a power source to prevent personal injury.
    • The volume rocker and power button located on the top edge by the camera are not connected pieces and will become free from the device once the front panel is removed from the back case. They are easily put back in place when reassembling the tablet.
    • Position the tablet with the top edge by the camera facing down.
    • Insert the plastic opening tool between the front panel and back case at the upper left hand corner of the tablet.
  2. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: 手順 2、 2の画像 1 Insignia Flex 10.1 NS-P10A6100 Screen Replacement: 手順 2、 2の画像 2
    • Slide the plastic opening tool along the edge of the tablet between the front panel and back case.
    • Repeat this process for the two shorter edges of the tablet leaving the top edge by the camera still snapped in place.
  3. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: 手順 3、 1の画像 1
    • Using an unfolding motion along the top edge of the tablet, carefully separate the front panel from the back case.
  4. Insignia Flex 10.1 NS-P10A6100 Screen Replacement, Camera: 手順 4、 2の画像 1 Insignia Flex 10.1 NS-P10A6100 Screen Replacement, Camera: 手順 4、 2の画像 2
    • Using the Phillips #000 screw driver, unscrew the two 4 mm screws securing the camera to the front panel in a counterclockwise direction.
    • The two screws are very small, so be careful not to lose them after unscrewing them.
  5. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: 手順 5、 1の画像 1
    • Using the plastic opening tool, lift up the black retaining flap that secures the camera ZIF (zero insertion force) ribbon connector to the motherboard.
  6. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: 手順 6、 1の画像 1
    • Pull the camera ZIF (zero insertion force) ribbon connector out from underneath the black retaining flap.
    • Remove the camera.
  7. Insignia Flex 10.1 NS-P10A6100 Screen Replacement, Screen: 手順 7、 2の画像 1 Insignia Flex 10.1 NS-P10A6100 Screen Replacement, Screen: 手順 7、 2の画像 2
    • Using the Phillips #000 screw driver, unscrew the four 4 mm screws securing the four gray clasps to the front panel in a counterclockwise direction.
    • The four screws are very small, so be careful not to lose them after unscrewing them.
  8. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: 手順 8、 1の画像 1
    • Using the plastic opening tool, pry the four gray clips from the front panel.
    • The gray clips rest lightly in place on the front panel, so minimal force is required to remove and place them.
  9. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: 手順 9、 3の画像 1 Insignia Flex 10.1 NS-P10A6100 Screen Replacement: 手順 9、 3の画像 2 Insignia Flex 10.1 NS-P10A6100 Screen Replacement: 手順 9、 3の画像 3
    • Using the Phillips #000 screw driver, unscrew the four 4 mm screws securing the speakers to the front panel in a counterclockwise direction.
  10. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: 手順 10、 2の画像 1 Insignia Flex 10.1 NS-P10A6100 Screen Replacement: 手順 10、 2の画像 2
    • Using the Phillips #000 screw driver, unscrew the three 4 mm screws securing the motherboard to the front panel in a counterclockwise direction.
    • The three screws are very small, so be careful not to lose them after unscrewing them.
  11. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: 手順 11、 1の画像 1
    • Using the plastic opening tool, lift up the black retaining flap that secures the volume and power button ZIF (zero insertion force) ribbon connector to the motherboard.
  12. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: 手順 12、 1の画像 1
    • Pull the ZIF (zero insertion force) ribbon connector out from underneath the black retaining flap.
  13. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: 手順 13、 2の画像 1 Insignia Flex 10.1 NS-P10A6100 Screen Replacement: 手順 13、 2の画像 2
    • Using the plastic opening tool, remove the silver tape covering the display ZIF (zero insertion force) ribbon connector.
  14. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: 手順 14、 1の画像 1
    • Using the plastic opening tool, lift up the black retaining flap that secures the display ZIF (zero insertion force) ribbon connector to the motherboard.
  15. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: 手順 15、 1の画像 1
  16. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: 手順 16、 1の画像 1
    • Position the tablet with the top edge by the cameras facing up.
    • Insert the heavy-duty spudger at the top right corner.
  17. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: 手順 17、 1の画像 1
    • Lift the screen from the front panel with a prying motion to detach it from the clips holding it in place.
  18. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: 手順 18、 1の画像 1
    • Pop the screen out from the front panel.
    • Be careful not to bend the front panel too much as it might break.
  19. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: 手順 19、 1の画像 1
    • Lift the screen from the front panel to remove.
終わりに
The screen is now free from the device and can be replaced. To reassemble your device, follow these instructions in reverse order.
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Samantha Damewood
メンバー登録日: 10/29/16
961 ポイント
5のガイドは作成済み
チーム
Baylor, Team 5-8, Williams Fall 2016 Baylor, Team 5-8, Williams Fall 2016人のメンバー
BU-WILLIAMS-F16S5G8
3 メンバー
12のガイドは作成済み
2 件のコメント
Do you have a guide for replacing the lcd screen?
dcutler01 - 返信
Whic screen models works wirt this tablet?
Gerardo Lerma - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 6
今までの合計 3,313
