メインコンテンツにスキップ
Infinity v2 10.1 Battery Replacement
必要な工具と部品
  1. Infinity v2 10.1 Battery Replacement, Back Case: 手順 1、 3の画像 1 Infinity v2 10.1 Battery Replacement, Back Case: 手順 1、 3の画像 2 Infinity v2 10.1 Battery Replacement, Back Case: 手順 1、 3の画像 3
    • Slightly pry open one corner of the device by using your finger nail to separate the screen from the back case.
    • Use an opening tool to carefully detach the back case from the tablet. Start by inserting the tool where your fingernail opened a gap, and work around all four sides of the device.
    • There will be a slight click noise as you free each tab.
    • Once the case is completely free, carefully lift it and place it face up on the workstation, being cautious not to damage the speaker wires connecting the two halves.
  2. Infinity v2 10.1 Battery Replacement: 手順 2、 2の画像 1 Infinity v2 10.1 Battery Replacement: 手順 2、 2の画像 2
    • Remove the speakers from the case by gently lifting them up and out of their slots.
  3. Infinity v2 10.1 Battery Replacement, Battery: 手順 3、 3の画像 1 Infinity v2 10.1 Battery Replacement, Battery: 手順 3、 3の画像 2 Infinity v2 10.1 Battery Replacement, Battery: 手順 3、 3の画像 3
    • Pry beneath each side of the battery using a spudger.
    • The adhesive may be too strong to manually remove, so heat can be applied using the iOpener. This evenly heats the adhesive and allows the battery to be lifted away easier. Do not place the iOpener directly on the battery; always apply heat on the opposite side of the device.
    • You may use a blow-dryer on a cool setting. Keep the dryer moving and at least 6 inches from the battery to prevent dangerous bubbling of the battery due to excess heat.
  4. Infinity v2 10.1 Battery Replacement: 手順 4、 2の画像 1 Infinity v2 10.1 Battery Replacement: 手順 4、 2の画像 2
    • Desolder the red and black wires connecting the battery to the motherboard.
    • Once the solder is melted, use tweezers to remove both wires from the motherboard.
    • The solder and iron will be extremely hot. Use tweezers to grab the wire to avoid burning your fingers from accidental contact with the iron.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Nate Rice
メンバー登録日: 10/31/19
321 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S2-G4, Barthe Fall 2019 UMass Dartmouth, Team S2-G4, Barthe Fall 2019人のメンバー
UMASSD-BARTHE-F19S2G4
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 9
今までの合計 268
