必要な工具と部品
Using the plastic opening tool, remove screen protector from front of monitor.
Unscrew the four 3 mm screws holding the motherboard to the unit using a Phillips #00 screwdriver.
ある他の人がこのガイドを完成しました。
2 件のコメント
I appreciate you posting this. What kind of new charging port did you use (USB type, size, etc) and does IFIXIT sell them?
John Lynch - 返信
The part you are looking for is a female Micro USB B-Type solder socket. I no longer have the unit available to confirm, but I'll bet you could contact Infant Optics and confirm with them. Sorry I can't be of more help!
