この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
As the projector heats up due to lamp use and processor heat, the fan speeds up to circulate cool air throughout the interior of the projector, and push hot air outside, so that the projector can continue to operate normally and not become damaged from overheating.
必要な工具と部品
Place the projector on its back (buttons down) with the lens facing away from you.
Remove the two 84mm screws in the upper left and right corners of the projector using the Phillips #2 screwdriver.
Remove the remaining three 8.5mm screws using the Phillips #1 screwdriver.
Flip the projector over and turn around so that the lens faces you.
Twist the gray zoom adjustment ring clockwise and extend the lens all the way out, and then slide the zoom adjustment ring all the way towards the end of the lens as far as it will go.
Slide the front case plate towards the loosened zoom adjustment ring, until the top plate of the projector is freed from underneath the lip of the front case plate.
2 の人々がこのガイドを完成させました。
