メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
IdeaPad L340-15API Fan Replacement
必要な工具と部品
  1. IdeaPad L340-15API Fan Replacement, Optical Drive: 手順 1、 2の画像 1 IdeaPad L340-15API Fan Replacement, Optical Drive: 手順 1、 2の画像 2
    • Before beginning the repair, make sure that the device is fully powered off.
    • Turn the laptop over so the bottom cover is facing up.
    • The small screw hole near the center of the case, marked with a tiny DVD icon and an arrow, secures the optical drive.
    FixBotに聞いてみる
  2. IdeaPad L340-15API Fan Replacement: 手順 2、 2の画像 1 IdeaPad L340-15API Fan Replacement: 手順 2、 2の画像 2
    • Use a Phillips #1 screwdriver to remove the 7.5 mm screw securing the optical drive.
    • Place the screw down safely in a container/magnet strip where it will not get lost while you are working. These screws are very small and easily misplaced.
    FixBotに聞いてみる
  3. IdeaPad L340-15API Fan Replacement: 手順 3、 2の画像 1 IdeaPad L340-15API Fan Replacement: 手順 3、 2の画像 2
    • Place your thumb at the seam between the optical drive and the device.
    • Gently pull the component straight out from the device, taking care not to pull at an angle.
    FixBotに聞いてみる
  4. IdeaPad L340-15API Fan Replacement, Battery: 手順 4、 2の画像 1 IdeaPad L340-15API Fan Replacement, Battery: 手順 4、 2の画像 2
    • Use a Phillips #1 screwdriver to remove the twelve 7.5 mm screws from the back cover.
    FixBotに聞いてみる
  5. IdeaPad L340-15API Fan Replacement: 手順 5、 3の画像 1 IdeaPad L340-15API Fan Replacement: 手順 5、 3の画像 2 IdeaPad L340-15API Fan Replacement: 手順 5、 3の画像 3
    • Insert a plastic opening pick in the back left corner and wedge the panel open.
    • Slide the pick around the edge of the laptop to release the clips as you lift the panel.
    • If the opening pick isn’t working, use the iFixit opening tool to gain more leverage.
    • Remove the bottom cover.
    FixBotに聞いてみる
  6. IdeaPad L340-15API Fan Replacement: 手順 6、 2の画像 1 IdeaPad L340-15API Fan Replacement: 手順 6、 2の画像 2
    • Use the Phillips #1 screwdriver to remove the five 6.5 mm screws securing the battery.
    • Use a container/magnet strip to store the screws while working.
    FixBotに聞いてみる
  7. IdeaPad L340-15API Fan Replacement: 手順 7、 3の画像 1 IdeaPad L340-15API Fan Replacement: 手順 7、 3の画像 2 IdeaPad L340-15API Fan Replacement: 手順 7、 3の画像 3
    • Use the wide end of a spudger to push the connector tab, sliding the battery connector out of its socket.
    • It may take a lot of force to disconnect the cable. Go slowly, and don't pull on the cables.
    FixBotに聞いてみる
  8. IdeaPad L340-15API Fan Replacement: 手順 8、 1の画像 1
    • Remove the battery from the laptop.
    FixBotに聞いてみる
  9. IdeaPad L340-15API Fan Replacement, Fan: 手順 9、 3の画像 1 IdeaPad L340-15API Fan Replacement, Fan: 手順 9、 3の画像 2 IdeaPad L340-15API Fan Replacement, Fan: 手順 9、 3の画像 3
    • Before you remove the fan, you need to remove the heatsink. The heatsink is the long copper piece connected to the fan.
    • Use a Phillips #1 screwdriver to loosen the four captive screws holding the heatsink in place.
    • The screws will stay connected to the heatsink but separate from the motherboard.
    • Gently lift the heatsink and set it aside for reassembly later.
    FixBotに聞いてみる
  10. IdeaPad L340-15API Fan Replacement: 手順 10、 2の画像 1 IdeaPad L340-15API Fan Replacement: 手順 10、 2の画像 2
    • Slide a thin, ESD-safe pry tool or angled tweezers under the metal neck of the connectors (as close to the head as possible) and lift straight up from the board to disconnect the black and gray coaxial cables from the Wi-Fi chip.
    • Always lift the connector straight up. Prying at an angle can break the socket off the board and permanently damage the motherboard.
    • Use tweezers to hold the connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again.
    FixBotに聞いてみる
  11. IdeaPad L340-15API Fan Replacement: 手順 11、 3の画像 1 IdeaPad L340-15API Fan Replacement: 手順 11、 3の画像 2 IdeaPad L340-15API Fan Replacement: 手順 11、 3の画像 3
    • Use the point of a spudger to push on alternating sides of the fan connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket.
    FixBotに聞いてみる
  12. IdeaPad L340-15API Fan Replacement: 手順 12、 2の画像 1 IdeaPad L340-15API Fan Replacement: 手順 12、 2の画像 2
    • Use a Phillips #1 screwdriver to remove the 6.5 mm screw holding the fan in place.
    FixBotに聞いてみる
  13. IdeaPad L340-15API Fan Replacement: 手順 13、 3の画像 1 IdeaPad L340-15API Fan Replacement: 手順 13、 3の画像 2 IdeaPad L340-15API Fan Replacement: 手順 13、 3の画像 3
    • The fan should be loose but it still has the Wi-Fi cables connected to it.
    • Detach the cables from the cable clips surrounding the fan.
    • The fan should be completely disconnected from the device.
    FixBotに聞いてみる
終わりに
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
作成者
3人の作成者と共同で作成されました。
Jasmyn
メンバー登録日: 10/16/25
205 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 2-5, Bowman Fall 2025 UMass Dartmouth, Team 2-5, Bowman Fall 2025人のメンバー
UMASSD-BOWMAN-F25S2G5
4 メンバー
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 34
今までの合計 167
