メインコンテンツにスキップ
Ibanez Guitar Neck and Bridge Pickups Replacement
必要な工具と部品
  1. Ibanez Guitar Neck and Bridge Pickups Replacement, Neck and Bridge Pickups: 手順 1、 2の画像 1 Ibanez Guitar Neck and Bridge Pickups Replacement, Neck and Bridge Pickups: 手順 1、 2の画像 2
    • Turn the tuning pegs in a counterclockwise direction to loosen the strings.
    • Pull the strings from the tuning pegs and thread them out the back of the guitar.
  2. Ibanez Guitar Neck and Bridge Pickups Replacement: 手順 2、 1の画像 1
    • Use a soft cloth or a guitar cleaning kit to wipe down the body, neck, and fretboard.
  3. Ibanez Guitar Neck and Bridge Pickups Replacement: 手順 3、 2の画像 1 Ibanez Guitar Neck and Bridge Pickups Replacement: 手順 3、 2の画像 2
    • Use the screwdriver to loosen each screw on the pickguard.
    • Remove knobs and pickup selector switch.
    • These knobs can be very tough to remove. If you feel like you may damage them by forcing them off, just leave them on.
  4. Ibanez Guitar Neck and Bridge Pickups Replacement: 手順 4、 1の画像 1
    • Remove the old pickups from the guitar body.
  5. Ibanez Guitar Neck and Bridge Pickups Replacement: 手順 5、 2の画像 1 Ibanez Guitar Neck and Bridge Pickups Replacement: 手順 5、 2の画像 2
    • Desolder connections from both red and green wire bundles.
    • There should be three separate wires per bundle that need to be individually removed.
    • For soldering help, visit this guide.
  6. Ibanez Guitar Neck and Bridge Pickups Replacement: 手順 6、 2の画像 1 Ibanez Guitar Neck and Bridge Pickups Replacement: 手順 6、 2の画像 2
    • Solder the new pickup wires to your control board.
    • Place your new pickups in the guitar body.
    • We highly recommend having a manual pertaining to your specific pickups. It will show you where each specific wire needs to be attached.
  7. Ibanez Guitar Neck and Bridge Pickups Replacement: 手順 7、 1の画像 1
    • Use the screwdriver to reinstall pickguard screws.
    • Re-attach pickup selector and knobs.
    • Not all screw locations are visible in the image. Make sure to use all of them.
  8. Ibanez Guitar Neck and Bridge Pickups Replacement: 手順 8、 2の画像 1 Ibanez Guitar Neck and Bridge Pickups Replacement: 手順 8、 2の画像 2
    • Thread your new strings through the back of the guitar, up to the tuning pegs, and tighten the strings.
    • Use the wire cutters to trim excess string from the ends.
ゴール
作成者
2人の作成者と共同で作成されました。
Joe Torres
メンバー登録日: 02/21/23
157 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 2-12, Raign Spring 2023 University of North Texas, Team 2-12, Raign Spring 2023人のメンバー
UNT-RAIGN-S23S2G12
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 46
今までの合計 343
