はじめに
Use this guide to remove and replace the display of a Huawei P8.
必要な工具と部品
Remove the two Torx T2 screws located at the bottom next to the micro USB port.
Pour ma part le Huawei P8 que j’ai démonté comprenait des vis T3 et non P2 ainsi qu’un port micro USB et non USB type C.
To reassemble your device, follow these instructions in reverse order. Reapply adhesive where necessary.
10 の人々がこのガイドを完成させました。
2 件のコメント
Is there any difference on screen frame between GRA-L09 and GRA-TL10??? The l09 is the single sim and the TL10 is the dual sim…
installing a new screen the first time, i was looking at darkness. then, taking it apart again and taking away the protective foil on the back of the screen, it just showed pink/purple colors and started heating up pretty bad around the charging connector. my idea would be a short circuit. any idea what is going wrong and can this still be saved?
