メインコンテンツにスキップ
Huawei P20 Battery Disconnect Procedure
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
必要な工具と部品
  1. Huawei P20 Battery Disconnect Procedure, Rear Glass: 手順 1、 1の画像 1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
  2. Huawei P20 Battery Disconnect Procedure: 手順 2、 3の画像 1 Huawei P20 Battery Disconnect Procedure: 手順 2、 3の画像 2 Huawei P20 Battery Disconnect Procedure: 手順 2、 3の画像 3
    • Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the cover and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner.
  3. Huawei P20 Battery Disconnect Procedure: 手順 3、 2の画像 1 Huawei P20 Battery Disconnect Procedure: 手順 3、 2の画像 2
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Huawei P20 Battery Disconnect Procedure: 手順 4、 3の画像 1 Huawei P20 Battery Disconnect Procedure: 手順 4、 3の画像 2 Huawei P20 Battery Disconnect Procedure: 手順 4、 3の画像 3
    • Insert a third opening pick at the bottom left corner.
    • In the next few steps whilst cutting around the power button and rear camera make sure you only use the tip of the opening pick to avoid cutting the cable, smearing the lens or damaging the camera.
    • Start to slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
    • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
  5. Huawei P20 Battery Disconnect Procedure: 手順 5、 2の画像 1 Huawei P20 Battery Disconnect Procedure: 手順 5、 2の画像 2
    • If the adhesive becomes hard to cut it most likely cooled down. Use your iOpener to reheat it.
    • Insert a fourth opening pick under the top left corner of the back cover.
    • Slide the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Huawei P20 Battery Disconnect Procedure: 手順 6、 2の画像 1 Huawei P20 Battery Disconnect Procedure: 手順 6、 2の画像 2
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right side to cut the remaining adhesive.
  7. Huawei P20 Battery Disconnect Procedure: 手順 7、 2の画像 1 Huawei P20 Battery Disconnect Procedure: 手順 7、 2の画像 2
    • Lift and remove the back cover.
    • Before installing fresh adhesive and reassembling, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
  8. Huawei P20 Battery Disconnect Procedure, Motherboard Cover with NFC: 手順 8、 2の画像 1 Huawei P20 Battery Disconnect Procedure, Motherboard Cover with NFC: 手順 8、 2の画像 2
    この手順で使用する道具:
    • Use a pair of tweezers to peel the black tape next to the rear camera off the motherboard cover.
  9. Huawei P20 Battery Disconnect Procedure: 手順 9、 1の画像 1
    • Remove the eight Phillips #00 screws (3.1 mm length).
  10. Huawei P20 Battery Disconnect Procedure: 手順 10、 2の画像 1 Huawei P20 Battery Disconnect Procedure: 手順 10、 2の画像 2
    • Use a pair of tweezers to peel the black foil at the bottom end of the phone off the loudspeaker.
  11. Huawei P20 Battery Disconnect Procedure: 手順 11、 2の画像 1 Huawei P20 Battery Disconnect Procedure: 手順 11、 2の画像 2
    • Slide an opening pick under the right side of the motherboard cover.
    • Rotate the opening pick slightly to pry up the motherboard cover.
  12. Huawei P20 Battery Disconnect Procedure: 手順 12、 3の画像 1 Huawei P20 Battery Disconnect Procedure: 手順 12、 3の画像 2 Huawei P20 Battery Disconnect Procedure: 手順 12、 3の画像 3
    • Remove the motherboard cover with NFC.
  13. Huawei P20 Battery Disconnect Procedure, Battery Disconnect: 手順 13、 2の画像 1 Huawei P20 Battery Disconnect Procedure, Battery Disconnect: 手順 13、 2の画像 2
    • Use a spudger to pry up and disconnect the battery connector.
終わりに
Dominik Schnabelrauch
メンバー登録日: 11/23/16
230,508 ポイント
682のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,577のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 14
今までの合計 43
