はじめに
Use this guide to replace the headphone jack in your Huawei P10 smartphone. When reassembling your phone apply new adhesive where it is necessary.
必要な工具と部品
Switch off your phone.
Remove the two Pentalobe P2 screws at the bottom.
Remove the SIM card tray.
Remove the Phillips #00 screw.
Use tweezers to remove the metal plate.
Use a spudger to disconnect the battery flex cable.
Remove the three Phillips #00 screws.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
2 の人々がこのガイドを完成させました。
