メインコンテンツにスキップ
Huawei Mate 10 Pro Charging Port Replacement
必要な工具と部品
  1. Huawei Mate 10 Pro Charging Port Replacement, Back Cover: 手順 1、 1の画像 1
    • Switch off your phone.
    • Prepare an iOpener and apply it to the back of the phone for about two minutes to loosen the adhesive beneath the back cover.
  2. Huawei Mate 10 Pro Charging Port Replacement: 手順 2、 3の画像 1 Huawei Mate 10 Pro Charging Port Replacement: 手順 2、 3の画像 2 Huawei Mate 10 Pro Charging Port Replacement: 手順 2、 3の画像 3
    この手順で使用する道具:
    Halberd Spudger
    $2.99
    • Lift up the back cover with a suction cup until you can insert the flat end of a halberd spudger.
    • Use the halberd spudger to cut the adhesive beneath the back cover on all sides of the phone.
    • Use opening picks to avoid the adhesive from sticking to the back cover again while cutting the adhesive on all sides.
  3. Huawei Mate 10 Pro Charging Port Replacement: 手順 3、 2の画像 1 Huawei Mate 10 Pro Charging Port Replacement: 手順 3、 2の画像 2
    • Don't remove the back cover all the way, yet. The fingerprint sensor cable is still connected to motherboard.
    • Flip the back cover over to the side.
    • Remove the Phillips #00 screw which holds down the metal shield, sitting on top of the connection of the fingerprint sensor cable.
  4. Huawei Mate 10 Pro Charging Port Replacement: 手順 4、 2の画像 1 Huawei Mate 10 Pro Charging Port Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    • Use a pair tweezers to remove the metal shield covering the connector of the fingerprint sensor.
    • Disconnect the fingerprint sensor cable with a spudger.
    • When reassembling your phone apply new adhesive where it is necessary.
  5. Huawei Mate 10 Pro Charging Port Replacement, Shields: 手順 5、 3の画像 1 Huawei Mate 10 Pro Charging Port Replacement, Shields: 手順 5、 3の画像 2 Huawei Mate 10 Pro Charging Port Replacement, Shields: 手順 5、 3の画像 3
    • Remove the twelve Phillips #00 screws.
    • Carefully remove the shields on top of the motherboard and the charging board.
    • In case the shields do not pop out easily on their own after you removed the Phillips screws, you can use the pointed end of a spudger to pry them out.
  6. Huawei Mate 10 Pro Charging Port Replacement, Charging Port: 手順 6、 2の画像 1 Huawei Mate 10 Pro Charging Port Replacement, Charging Port: 手順 6、 2の画像 2
    • Use a spudger to disconnect the charging port flex cable from the motherboard and from the daughterboard.
  7. Huawei Mate 10 Pro Charging Port Replacement: 手順 7、 2の画像 1 Huawei Mate 10 Pro Charging Port Replacement: 手順 7、 2の画像 2
    この手順で使用する道具:
    • Use a pair of tweezers to carefully remove the charging port including its flex cable.
    • The charging port sits tightly in its recess. In case you have trouble removing it, use the flat end of a halberd spudger to pry it out.
終わりに
18 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Dominik Schnabelrauch
メンバー登録日: 11/23/16
228,969 ポイント
682のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,418のガイドは作成済み
2 件のコメント
Great tutorial! It has been a month without being able to charge my phone, and now it charges 2x as fast with my repair.
Bruce Panagopoulos - 返信
I recommend testing the USB C flex cable assembly before you reassemble the phone. As soon as it’s connected to the upper connector and the battery is plugged in the phone should be charging. Mine was broken from the factory but I went to a great local repair shop and got a new one, the guy said 1 out of 15 is broken from the factory. Great tutorial, successful repair.
Martin Olsson - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 19
過去 30 日: 61
今までの合計 17,022
