はじめに
Be careful to not force the pin in or out incorrectly. If it is difficult to press the pin through the chain, the tool is most likely not aligned up properly. Greasing the threads of the chain cutting tool will make it easier to press in or out the pin.
ツール
パーツ
パーツは指定されていません。
Slide the chain cutting tool onto the desired link.
Align the push pin of the tool with the pin on the chain, and tighten the tool until the pin protrudes out the other side without falling all the way out.
Rout the chain around the front chain rings and rear derailleur.
Pull the ends of the chain together.
After re-inserting the chain pin, make sure that the chain links move freely. Occasionally, pressing the pin into the chain will cause excess friction on the side links, causing the two links to not flex properly. You can fix this by adjusting how you push the pin through, and also by adjusting the links with a pair of needle-nosed pliers.
ある他の人がこのガイドを完成しました。
