この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Considering the steps in this guide were completed by 2 people, it is recommended that this guide is attempted with two or more people
Required Tools
- T-9 Screwdriver
- Needle-Nose Pliers
Recommended
*An Additional Person for step 9
必要な工具と部品
First, begin by removing the printer's hood.
Open the printer's mouth by simply pulling down on it; there are 2 mouth pieces that need to be pulled down.
Adjust the flap covering the scanner upward, as shown.
To access and remove the fourth and final screw attaching the hood, the panel for the power button must be removed as follows:
Reach into the mouth of the printer and press on the small clip behind the power button. This allows the panel of the power button to be removed.
After pressing the clip, pull out the power button panel by pulling from right to left.
This step is easier with two people. Carefully have one person lift the hood of the printer 2-3 inches above where it was resting.
Remove the ribbon cables and wires attaching the motherboard (the only green PCB board) to the hood by gently pulling upward on them.
When all three cables are removed, lift the hood away from the printer and set it aside.
After being separated from the printer, the hood is ready to be disassembled.
Remove the only screw on the printer hood's underside, as shown. Use a T-9 screwdriver.
After having the hood removed and disassembled, locate the scanner.
Adjust the scanner wheel such that fits into the path.
If the black ribbon cable is twisted, untwist it so it appears as shown.
2 の人々がこのガイドを完成させました。
