メインコンテンツにスキップ
How to join two wires with solder
必要な工具と部品
  1. How to join two wires with solder, How to join two wires with solder: 手順 1、 1の画像 1
    • Put one of the paired wires on one of the helping hand's clamp. Put the other pair of wires on the remaining clamp.
    • Make sure the wires' stripped ends are facing each other or are towards the center of the workplace. If not, orientate the wires accordingly.
  2. How to join two wires with solder: 手順 2、 2の画像 1 How to join two wires with solder: 手順 2、 2の画像 2
    • Using both stripped wire ends, wrap and tie both of the ends together.
  3. How to join two wires with solder: 手順 3、 1の画像 1
    • Solder the tied ends of the filament.
    • Ensure to solder the connection completely, not just one area.
    • Try not to put too much solder on the connection, as it will add more resistance.
  4. How to join two wires with solder: 手順 4、 1の画像 1
    • Pull on the two wires firmly to ensure the solder does not separate.
  5. How to join two wires with solder: 手順 5、 2の画像 1 How to join two wires with solder: 手順 5、 2の画像 2
    • To properly protect the soldered wire connection, use heat shrink.
    • Cut enough heat shrink to cover the soldered connection.
    • Slip the heat shrink onto the connection.
    • Using a heat generator, such as a heat gun or a hairdryer, heat the heat shrink around all of the angles until it securely covers the soldered connection.
終わりに
This technique will allow wires to be extended both electrically and structurally without the need of longer wires.
8 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Joeny Zhen
メンバー登録日: 02/24/15
427 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 23-1, Green Winter 2015 Cal Poly, Team 23-1, Green Winter 2015人のメンバー
CPSU-GREEN-W15S23G1
4 メンバー
4のガイドは作成済み
コメント 1 件
Perhaps I might recommend sliding the H.S. tubing on before soldering the joint in case the wires are connected on the other end to something else.
Nathaniel Loeblein - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 24
今までの合計 3,737
