メインコンテンツにスキップ
How to clean the Shure SM58 XLR connector
必要な工具と部品
  1. How to clean the Shure SM58 XLR connector, XLR Microphone Connector Disassembly: 手順 1、 1の画像 1
    • Using a small flat head screwdriver, gently turn the retaining screw at the bottom of the microphone counterclockwise until it stops or provides resistance.
    • The retaining screw is mounted to the connector and has a left-handed thread. Turning the screw clockwise locks the connector in place. Turning it counterclockwise lowers it down into the hole, releasing the connector.
    • Once the screw stops, do not try to loosen it further.
  2. How to clean the Shure SM58 XLR connector: 手順 2、 1の画像 1
    • Plug an XLR cable into the loose connector.
    • While holding the disconnect button down, pull on the cable to remove the connector from the body of the microphone.
  3. How to clean the Shure SM58 XLR connector, How to clean the Shure SM58 XLR connector: 手順 3、 1の画像 1
    • Using a detailing brush, gently brush the pins and inside walls of the microphone.
  4. How to clean the Shure SM58 XLR connector: 手順 4、 1の画像 1
    • Do not solder microphone parts without prior soldering experience.
    • Only attempt this step if you have previously soldered inside the microphone. If the pins on the inside of the connector have excess solder on them, take a soldering iron and melt of excess solder.
  5. How to clean the Shure SM58 XLR connector: 手順 5、 1の画像 1
終わりに
To reassemble your device, follow these instructions in reverse order. After cleaning the connector, your microphone is ready to connect to XLR cables.
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
nat coll
メンバー登録日: 09/27/12
642 ポイント
14のガイドは作成済み
チーム
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012人のメンバー
CPSU-FORTE-F12S7G53
5 メンバー
20のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 24
今までの合計 4,133
