メインコンテンツにスキップ
How to clean and reapply thermal paste on ATI Radeon X1900 XTX
必要な工具と部品
  1. How to clean and reapply thermal paste on ATI Radeon X1900 XTX, How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 手順 1、 2の画像 1 How to clean and reapply thermal paste on ATI Radeon X1900 XTX, How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 手順 1、 2の画像 2
    • Start by removing the card from the PC if you haven't already.
  2. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 手順 2、 3の画像 1 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 手順 2、 3の画像 2 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 手順 2、 3の画像 3
    • The fan's power cable is located towards the bottom-left of the card.
    • Disconnect the cable from the card.
    • The cable and its connector on the X1900 are fragile. Be careful, and try not to use excessive force when removing it.
  3. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 手順 3、 3の画像 1 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 手順 3、 3の画像 2 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 手順 3、 3の画像 3
    • Removing the heatsink from the card:
    • The clamp is held on by four small Phillips screws. Remove them, then the clamp.
    • Remove the four phillips screws surrounding the clamp.
  4. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 手順 4、 1の画像 1
    • Separate the heatsink and the card.
  5. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 手順 5、 2の画像 1 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 手順 5、 2の画像 2
    • Replacing Thermal Paste:
    • Using a Q-tip/cotton swab and rubbing alcohol, clean the copper plate that protrudes from the bottom of the heatsink.
  6. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 手順 6、 2の画像 1 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 手順 6、 2の画像 2
    • Removing the heatsink's plastic cover:
    • Remove these Phillips screws.
    • Seperate the plastic cover from the metal heat sink.
  7. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 手順 7、 2の画像 1 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 手順 7、 2の画像 2
    • Cleaning dust out of the heat sink:
    • Using a cotton swab/q-tip, clean the edges of the heat sink. You can also use canned air if available.
  8. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 手順 8、 2の画像 1 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 手順 8、 2の画像 2
    • Using the same method that you used to clean the copper plate, clean the surface of the GPU die.
  9. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 手順 9、 3の画像 1 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 手順 9、 3の画像 2 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 手順 9、 3の画像 3
    • Re-Applying Thermal Paste:
    • Apply a small glob of thermal paste to the corner of the die, (I recommend using Arctic Silver 5) and use an index card to spread a thin, even layer of it over the surface of the chip.
    • For more detailed directions, follow our Applying Thermal Paste Guide.
終わりに
13 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Chris Green
メンバー登録日: 10/11/09
37,014 ポイント
49のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
321 メンバー
1,464のガイドは作成済み
コメント 1 件
Super!!!!! j'ai suivi a la lettre; j'espère sauver ma carte; j'attends la pate thermique.
guz - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 38
今までの合計 13,303
