メインコンテンツにスキップ
How to True Bicycle wheels
必要な工具と部品
  1. How to True Bicycle wheels, How to True Bicycle wheels: 手順 1、 2の画像 1 How to True Bicycle wheels, How to True Bicycle wheels: 手順 1、 2の画像 2
    • Fit the wheel into the wheel truing stand. It doesn't matter which way the wheel is facing.
    • The wheel should be snug and securely fixed to the stand.
    • Tighten the quick-release nut and lever, making sure that there is no room for the wheel to wiggle in the truing stand.
  2. How to True Bicycle wheels: 手順 2、 2の画像 1 How to True Bicycle wheels: 手順 2、 2の画像 2
    • Bring the calipers up until the teeth are are about half an inch from the metal rim of the wheel.
    • Start the wheel spinning slowly.
    • Slowly tighten the calipers until they contact the wheel on one side or the other.
  3. How to True Bicycle wheels: 手順 3、 2の画像 1 How to True Bicycle wheels: 手順 3、 2の画像 2
    • Loosen the spoke nipples that attach to the same side of the wheel that the caliper is touching. At the same time, tighten the spokes that attach to the opposite side of the hub.
    • As a starting point, turn all the spokes half of a turn for each of the spokes near the caliper contact point.
    • In the photo, the red marked spokes are being tightened, and the blue marked spokes are being loosened. This will shift the rim closer to the viewer.
    • Spin the wheel. Tighten the calipers again until they touch the rim on only one side at a time at certain point. Repeat steps 2-3 until the caiplers touch both sides of the rim evenly at every point on the rim.
終わりに
The wheel should spin without wobbling from side to side or wavering up and down
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Brett Hartt
メンバー登録日: 04/12/10
129,824 ポイント
143のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,437のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 14
今までの合計 5,425
