メインコンテンツにスキップ
How to Shorten Straps on a Tank Top by Hand
必要な工具と部品
  1. How to Shorten Straps on a Tank Top by Hand, How to Shorten Straps on a Tank Top by Hand: 手順 1、 2の画像 1 How to Shorten Straps on a Tank Top by Hand, How to Shorten Straps on a Tank Top by Hand: 手順 1、 2の画像 2
    • Put on the top.
    • Hold and stretch the strap to the desired length.
    • Secure the desired length of the strap with a safety pin.
    • Be careful with the safety pin while securing the strap.
  2. How to Shorten Straps on a Tank Top by Hand: 手順 2、 1の画像 1
    • Use a fabric pencil to mark both sides of the strap right above the safety pin.
  3. How to Shorten Straps on a Tank Top by Hand: 手順 3、 1の画像 1
    • Remove the safety pin.
    • Use the ruler to measure the length between the two marks.
    • This length of the strap will be removed at the last step.
  4. How to Shorten Straps on a Tank Top by Hand: 手順 4、 2の画像 1 How to Shorten Straps on a Tank Top by Hand: 手順 4、 2の画像 2
    • Place the top down so the back is facing up.
    • Place one end of the ruler where the strap meets the back of the shirt.
    • Use the fabric pencil to mark the strap, using the measurement from the previous step.
  5. How to Shorten Straps on a Tank Top by Hand: 手順 5、 3の画像 1 How to Shorten Straps on a Tank Top by Hand: 手順 5、 3の画像 2 How to Shorten Straps on a Tank Top by Hand: 手順 5、 3の画像 3
    • Draw a line with the fabric pencil on the seam below the strap on either side of the strap.
    • This is where you will sew the strap back in place.
  6. How to Shorten Straps on a Tank Top by Hand: 手順 6、 2の画像 1 How to Shorten Straps on a Tank Top by Hand: 手順 6、 2の画像 2
    • Use the seam ripper to rip the seams from the back of the strap where it meets the back of the shirt.
  7. How to Shorten Straps on a Tank Top by Hand: 手順 7、 3の画像 1 How to Shorten Straps on a Tank Top by Hand: 手順 7、 3の画像 2 How to Shorten Straps on a Tank Top by Hand: 手順 7、 3の画像 3
    • Turn the top inside out.
    • Match the strap with the lines from Steps 4 and 5.
    • Pin the strap so it stays in place.
  8. How to Shorten Straps on a Tank Top by Hand: 手順 8、 3の画像 1 How to Shorten Straps on a Tank Top by Hand: 手順 8、 3の画像 2 How to Shorten Straps on a Tank Top by Hand: 手順 8、 3の画像 3
    • Use a needle and a thread that has a similar color to the fabric to sew the strap to the seam of the top.
    • Use the white lines from the fabric pencil as a guide.
    • Pierce the needle through the fabric of the top and then pull the needle through the strap.
    • Continue the same process downwards until reaching the end of the seam of the top.
    • Tie a knot after pulling the string.
    • Cut the excess thread.
    • Repeat the step for the opposite side of the strap and the upper side of the strap.
  9. How to Shorten Straps on a Tank Top by Hand: 手順 9、 1の画像 1
    • Put the top back on.
    • Make sure the top fits properly. If not, repeat the guide from Step 1.
  10. How to Shorten Straps on a Tank Top by Hand: 手順 10、 1の画像 1
    • Use fabric scissors to cut the excess fabric.
    • Repeat all the steps for the other strap.
ゴール
作成者
1人の作成者と共同作成されました。
Victoria Reyes
メンバー登録日: 10/06/21
181 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 12
過去 7 日: 75
過去 30 日: 284
今までの合計 9,021
