はじめに
She’s got fuel, she sparks, but she still won’t light. Your Zippo probably needs a new wick, here's how to replace your spent one.
必要な工具と部品
Be sure your work area is clear of any flammable liquids after you finish this replacement.
21 の人々がこのガイドを完成させました。
5 Guide Comments
The wick won't go into that tiny little hole so easily. It won't even get started enough to pull it through the other end. Trying to get it in there, frazzles the end of the wick which further makes it impossible to get it into the hole.
barbaraebj - 返信
Can't u just pull it up to get fresh wick?Call
On a Zippo-style copy I have there is a small screw that holds a spring bearing on the top lever through which the wick passes. The hole in the centre of the screw seems too small for the standard Zippo wick to pass through. Does anybody know if a smaller diameter wick is available?
مرحبا شكد سعار اكو توصيل العراق
عبوسي KING〆 - 返信
