メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to Replace the Back Panel Adhesive on Your Google Pixel 4 XL
必要な工具と部品
  1. How to Replace the Back Panel Adhesive on Your Google Pixel 4 XL, Scrape off the old adhesive: 手順 1、 3の画像 1 How to Replace the Back Panel Adhesive on Your Google Pixel 4 XL, Scrape off the old adhesive: 手順 1、 3の画像 2 How to Replace the Back Panel Adhesive on Your Google Pixel 4 XL, Scrape off the old adhesive: 手順 1、 3の画像 3
    • When scraping the frame and back panel, take care not to damage the cameras, spring contacts, and graphite film.
    • Use the flat end of a spudger or your fingernail to scrape off the old adhesive from the frame and back panel.
  2. How to Replace the Back Panel Adhesive on Your Google Pixel 4 XL, Remove the remaining adhesive: 手順 2、 2の画像 1 How to Replace the Back Panel Adhesive on Your Google Pixel 4 XL, Remove the remaining adhesive: 手順 2、 2の画像 2
    この手順で使用する道具:
    Microfiber Cleaning Cloths
    $3.99
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol to any remaining adhesive.
    • Use a microfiber cloth to remove the remaining adhesive.
    • If you're still having trouble removing the adhesive, apply a few drops of alcohol to the adhesive and scrape it with a spudger.
  3. How to Replace the Back Panel Adhesive on Your Google Pixel 4 XL, Orient the adhesive: 手順 3、 1の画像 1
    • Before peeling off any liners, lay the new adhesive down on the back panel and use the camera cutout to find its proper orientation.
  4. How to Replace the Back Panel Adhesive on Your Google Pixel 4 XL, Remove the adhesive liner: 手順 4、 1の画像 1
    • Peel and remove the large rectangular liner.
    • This should expose the adhesive that will stick to the back panel.
  5. How to Replace the Back Panel Adhesive on Your Google Pixel 4 XL, Apply the adhesive: 手順 5、 3の画像 1 How to Replace the Back Panel Adhesive on Your Google Pixel 4 XL, Apply the adhesive: 手順 5、 3の画像 2 How to Replace the Back Panel Adhesive on Your Google Pixel 4 XL, Apply the adhesive: 手順 5、 3の画像 3
    • Be very careful during this step! The adhesive is very sticky, and once it touches the back panel you won't be able to reposition it. Misaligned adhesive can lead to an improper seal.
    • When laying down the adhesive, make sure the back panel connector cable is threaded through the camera cutout. If the adhesive sticks to the cable, you'll have to restart the repair with new adhesive.
    • With the adhesive in its proper orientation, lay it sticky side down on the back panel.
    • Press down firmly around the perimeter of the back panel, ensuring all the adhesive is secured.
  6. How to Replace the Back Panel Adhesive on Your Google Pixel 4 XL: 手順 6、 2の画像 1 How to Replace the Back Panel Adhesive on Your Google Pixel 4 XL: 手順 6、 2の画像 2
    • Use the pull tabs to remove all remaining liners from the adhesive.
  7. How to Replace the Back Panel Adhesive on Your Google Pixel 4 XL: 手順 7、 1の画像 1
    • Return to your phone's repair guide and continue reassembly.
    • Be very careful when reassembling your device, as the adhesive is exposed and very sticky. Take special care to prevent the back panel cable from touching the adhesive.
    • Return to this guide before securing the back panel to the phone.
  8. How to Replace the Back Panel Adhesive on Your Google Pixel 4 XL: 手順 8、 3の画像 1 How to Replace the Back Panel Adhesive on Your Google Pixel 4 XL: 手順 8、 3の画像 2 How to Replace the Back Panel Adhesive on Your Google Pixel 4 XL: 手順 8、 3の画像 3
    • Align the back panel over the back of the phone and lay it down.
    • Secure the back panel by firmly pressing along its perimeter for one minute.
ゴール
5 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Spencer Day
メンバー登録日: 09/14/22
159,326 ポイント
1,043のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,927のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 43
今までの合計 2,453
