はじめに
Use this guide to replace the back cover adhesive by applying it to the frame first.
To determine where you first apply the adhesive, match the contours of the adhesive on the clear side with the back cover and the frame. If your adhesive strip matches the bottom cover, follow this guide instead.
The frame-first adhesive tends to have screw holes in the colored lining.
必要な工具と部品
If you're re-using your frame, remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat and isopropyl alcohol (90% or greater) if you're having trouble removing the adhesive.
Repeat the same procedure for any remaining adhesive on the back cover.
Before removing any liners, position the adhesive strip with the clear liner facing down over the frame to find the proper orientation.
If the adhesive matches the back cover instead of the frame, follow this cover-first adhesive guide.
Carefully align the sticky side of the adhesive over the edges of the frame.
Press down on the perimeter of the adhesive strip to bond it to the frame.
17 の人々がこのガイドを完成させました。
2件のガイドコメント
Many thanks for the instructions.
Note:
Unfortunately, removing the old adhesive is a laborious process that requires a lot of effort. (Samsung Note 20 Ultra 5G with adhesive film that has already completely dissolved on its own!)
Absolutely necessary - in addition to patience: ISOPROPANOL (e.g. https://amzn.eu/d/7ZIPJCJ) - this dissolves all adhesives (be careful)!
Carefully scrape off the adhesive layers with a plastic spatula - plus cotton swabs plus cosmetic tissues (do not leave lint) then laboriously remove the adhesive residue.
ISOPROPANOL 99.9% does not damage electronics, i.e. can therefore be used for cleaning without hesitation.
