メインコンテンツにスキップ
How to Replace a Speaker on a Yamaha PSS-130 Keyboard
必要な工具と部品
  1. How to Replace a Speaker on a Yamaha PSS-130 Keyboard, Internal Speaker: 手順 1、 2の画像 1 How to Replace a Speaker on a Yamaha PSS-130 Keyboard, Internal Speaker: 手順 1、 2の画像 2
    • Remove the battery cover.
    • Remove all twelve of the 9.0 mm screws on the back cover of the device's casing using a Phillips #1 screwdriver.
  2. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 手順 2、 3の画像 1 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 手順 2、 3の画像 2 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 手順 2、 3の画像 3
    • Place your fingers in the battery compartment, and place your thumb on the back of the keyboard.
    • Grip inside battery cover and push on the back of the keyboard with your thumb.
  3. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 手順 3、 2の画像 1 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 手順 3、 2の画像 2
    • Replace two 9.0 mm Phillips screws to keep the keys from falling out while working on this device.
  4. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 手順 4、 3の画像 1 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 手順 4、 3の画像 2 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 手順 4、 3の画像 3
    • Rotate the keyboard to get a better angle with the soldering iron.
  5. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 手順 5、 1の画像 1
    • Desolder the connections of the old speaker using the soldering iron and the solder wick.
  6. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 手順 6、 3の画像 1 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 手順 6、 3の画像 2 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 手順 6、 3の画像 3
    • Remove the fasteners using an 11 mm socket wrench.
    • It will take very little torque to strip the plastic, so make sure that your wrench is turning them to the left.
  7. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 手順 7、 2の画像 1 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 手順 7、 2の画像 2
    • The speaker should now be free. Simply lift the speaker out.
    • Using the same process, place the new speaker in the speaker indentation.
    • My own speaker was not malfunctioning so I did not replace it.
  8. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 手順 8、 1の画像 1
    • Replace the fasteners that were removed in step 6, this time tightening to the right.
  9. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 手順 9、 1の画像 1
    • Solder the new speaker to the wires taken off in step 5.
終わりに
To reassemble your device, follow these instructions in reverse order from step 3.
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Mikey
メンバー登録日: 03/23/20
229 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 10
今までの合計 555
