メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to Replace Seat Fabric/Cushioning
必要な工具と部品
  1. How to Replace Seat Fabric/Cushioning, Seat Fabric: 手順 1、 2の画像 1 How to Replace Seat Fabric/Cushioning, Seat Fabric: 手順 1、 2の画像 2
    • Unscrew the seat from the chair frame using a screwdriver.
    • The type of screws securing the seat to the frame will vary from manufacturer to manufacturer; choose the appropriate screwdriver for your particular chair.
  2. How to Replace Seat Fabric/Cushioning: 手順 2、 3の画像 1 How to Replace Seat Fabric/Cushioning: 手順 2、 3の画像 2 How to Replace Seat Fabric/Cushioning: 手順 2、 3の画像 3
    • Once the seat is separate from its base, flip it upside-down and remove the fabric staples with pliers.
    • Remove the fabric.
    • Optional: if you wish to replace the foam as well, place the seat base on top of the foam and trace around it with a marker. Use utility scissors to cut the foam.
  3. How to Replace Seat Fabric/Cushioning: 手順 3、 1の画像 1
    • Place the foam or chair seat on top of your desired fabric.
    • Use a pair of scissors to cut the fabric, tracing around the foam or seat. Cut the fabric approximately 1.5 inches wider on the sides to allow it to wrap around the edges.
  4. How to Replace Seat Fabric/Cushioning: 手順 4、 1の画像 1
    • Center the foam on the seat board, place the fabric on top of the foam, then flip the board over.
    • The fabric should be underneath and the board should be on the top.
    • Fold the fabric inward, toward the board.
    • Make sure the outside of the fabric is facing you as you fold it inward.
  5. How to Replace Seat Fabric/Cushioning: 手順 5、 2の画像 1 How to Replace Seat Fabric/Cushioning: 手順 5、 2の画像 2
    • Staple the fabric to the seat, around the entire perimeter.
    • It helps to have a friend hold the fabric taut while you staple.
    • After everything is stapled, cut excess fabric (if necessary) using a pair of scissors.
  6. How to Replace Seat Fabric/Cushioning: 手順 6、 2の画像 1 How to Replace Seat Fabric/Cushioning: 手順 6、 2の画像 2
    • Screw the refurbished seat back to the frame.
終わりに
You're all set! Enjoy your brand-new looking chair!
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Jannai Garcia
メンバー登録日: 03/18/22
187 ポイント
1ガイドが承認済み
チーム
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 4
過去 30 日: 21
今までの合計 902
