メインコンテンツにスキップ
How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.
必要な工具と部品
  1. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower., How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 手順 1、 1の画像 1
    • Start with a flat, open space to work.
  2. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 手順 2、 2の画像 1 How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 手順 2、 2の画像 2
    • Unscrew these three 1.2 mm screws.
  3. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 手順 3、 1の画像 1
    • Remove the Bubble Sprocket from the motor.
  4. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 手順 4、 1の画像 1
    • Unscrew these four 1.2mm screws holding the plate on.
  5. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 手順 5、 1の画像 1
    • Remove the plate.
  6. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 手順 6、 1の画像 1
    • Connect the red wire to the top right pin.
  7. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 手順 7、 1の画像 1
    • Solder the Red wire to the metal pin.
    • (Warning Soldering is very hot!)
  8. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 手順 8、 2の画像 1 How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 手順 8、 2の画像 2
    • Connect the yellow wire to the bottom right pin.
    • Solder the yellow wire to the bottom right pin.
    • (Warning Soldering iron is very hot!)
  9. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 手順 9、 1の画像 1
    • Replace the plate over the wires.
  10. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 手順 10、 1の画像 1
    • Put four 1.2 mm screws for the plate back into place.
  11. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 手順 11、 1の画像 1
    • Put three 1.2mm screws for the motor back into place.
  12. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 手順 12、 1の画像 1
    • Insert the Bubble sprocket onto the motor.
  13. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 手順 13、 1の画像 1
    • You are now finished!
ゴール
作成者
1人の作成者と共同作成されました。
John Hiller
メンバー登録日: 10/05/15
110 ポイント
1ガイドが承認済み
チーム
Colorado Springs, Team 7-5, Mcmichael Fall 2015 Colorado Springs, Team 7-5, Mcmichael Fall 2015人のメンバー
UCCS-MCMICHAEL-F15S7G5
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 10
過去 30 日: 21
今までの合計 1,817
