メインコンテンツにスキップ
How to Repair a Squareplug Patch Cable with SP400 Plugs
必要な工具と部品
  1. How to Repair a Squareplug Patch Cable with SP400 Plugs, Patch Cables With SP400 Plugs: 手順 1、 1の画像 1
    • Verify that the cable is faulty (unresponsive yellow and green LED indicators).
    • Yellow LED indicator
    • Green LED indicator
    • If both the yellow and green LED indicators turn on, then the cable is not the source of any audio loss. Check the pedals, amp, guitar, or power supply for issues.
    • If the red LED turns on, then the cable is shorting and will also require a resolder.
  2. How to Repair a Squareplug Patch Cable with SP400 Plugs: 手順 2、 1の画像 1
    • Unscrew the SP400 housing.
  3. How to Repair a Squareplug Patch Cable with SP400 Plugs: 手順 3、 3の画像 1 How to Repair a Squareplug Patch Cable with SP400 Plugs: 手順 3、 3の画像 2 How to Repair a Squareplug Patch Cable with SP400 Plugs: 手順 3、 3の画像 3
    • Desolder the existing solder connections.
    • Wick the existing solder completely off of the plug connections.
    • Do not touch the plug or the wick directly while desoldering.
    • For more information on soldering, check out the How to Solder and Desolder Connections guide.
  4. How to Repair a Squareplug Patch Cable with SP400 Plugs: 手順 4、 2の画像 1 How to Repair a Squareplug Patch Cable with SP400 Plugs: 手順 4、 2の画像 2
    • Cut the ends of the cable using a pair of wire cutters to expose fresh wires.
  5. How to Repair a Squareplug Patch Cable with SP400 Plugs: 手順 5、 3の画像 1 How to Repair a Squareplug Patch Cable with SP400 Plugs: 手順 5、 3の画像 2 How to Repair a Squareplug Patch Cable with SP400 Plugs: 手順 5、 3の画像 3
    • Strip the outer insulating jacket by ~1 cm.
    • The Eclipse UTP Stripper works especially well for this step.
    • Braid the ground wires.
  6. How to Repair a Squareplug Patch Cable with SP400 Plugs: 手順 6、 3の画像 1 How to Repair a Squareplug Patch Cable with SP400 Plugs: 手順 6、 3の画像 2 How to Repair a Squareplug Patch Cable with SP400 Plugs: 手順 6、 3の画像 3
    • Strip the inner insulator by ~2mm.
    • Braid the signal wires.
  7. How to Repair a Squareplug Patch Cable with SP400 Plugs: 手順 7、 3の画像 1 How to Repair a Squareplug Patch Cable with SP400 Plugs: 手順 7、 3の画像 2 How to Repair a Squareplug Patch Cable with SP400 Plugs: 手順 7、 3の画像 3
    • Tin the soldering iron tip, ground wire, signal wire, and plug connections.
    • Do not touch the plug or the solder directly while tinning.
  8. How to Repair a Squareplug Patch Cable with SP400 Plugs: 手順 8、 2の画像 1 How to Repair a Squareplug Patch Cable with SP400 Plugs: 手順 8、 2の画像 2
    • Solder the wires onto the plug connections:
    • Signal wire to the tip connection
    • Ground wire to the sleeve connection
    • The outer insulating jacket should slightly extend into the chamber of the plug to minimize cable movement.
    • Do not touch the plug directly while soldering.
  9. How to Repair a Squareplug Patch Cable with SP400 Plugs: 手順 9、 1の画像 1
    • Screw the SP400 housing.
  10. How to Repair a Squareplug Patch Cable with SP400 Plugs: 手順 10、 2の画像 1 How to Repair a Squareplug Patch Cable with SP400 Plugs: 手順 10、 2の画像 2
    • Verify that the cable is working (responsive yellow and green LED indicators).
ゴール
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Crystal Edwards
メンバー登録日: 09/21/18
450 ポイント
3のガイドは作成済み
チーム
University of North Texas, Team 1-3, Raign Spring 2022 University of North Texas, Team 1-3, Raign Spring 2022人のメンバー
UNT-RAIGN-S22S1G3
2 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 23
今までの合計 547
