はじめに
Use this guide to remove the rear panel in your LG WM3050CW Washing Machine.
Removing the rear panel gives you access to many internal components, such as the direct drive motor, dampers, and more.
必要な工具と部品
Turn off the main water supply
Unplug your washer
Disconnect all water connections at the rear of your washer
Use a Phillips driver to remove the four 10.7 mm‑long screws securing the rear panel.
Lift the rear panel upward to release its bottom clips.
Pull the rear panel away from the chassis to release the remaining clips.
Repair didn’t go as planned? Ask our Answers community for help.
