メインコンテンツにスキップ
How to Reattach a Broken Table Leg
必要な工具と部品
  1. How to Reattach a Broken Table Leg, How to Reattach a Broken Table Leg: 手順 1、 1の画像 1
    • Carefully place the table on an even surface and identify the broken parts.
  2. How to Reattach a Broken Table Leg: 手順 2、 1の画像 1
    • Carefully place the table with the tabletop face down on a clean cloth or plastic cover to prevent scratching.
    • You might need some assistance depending on the size of the table.
  3. How to Reattach a Broken Table Leg: 手順 3、 2の画像 1 How to Reattach a Broken Table Leg: 手順 3、 2の画像 2
    • Remove the screws from the broken leg.
    • I am using a Mastercraft flathead 3 mm screwdriver in this step. Your screwdriver type will depend on the screw. Follow this guide to learn more about screwdriver types.
    • Remove the broken leg.
    • Use a paper towel to clean the surface of the table and legs.
  4. How to Reattach a Broken Table Leg: 手順 4、 2の画像 1 How to Reattach a Broken Table Leg: 手順 4、 2の画像 2
    • Caution: If you have sensitive skin, avoid direct contact with the glue and use gloves before performing this step.
    • Caution: Use adequate ventilation or wear a mask to prevent inhaling the glue fumes.
    • Carefully apply the glue on the part that connects the table and legs.
  5. How to Reattach a Broken Table Leg: 手順 5、 1の画像 1
    • Press the leg against the glue for few minutes.
    • Allow the glue to dry for at least 10 minutes.
  6. How to Reattach a Broken Table Leg: 手順 6、 1の画像 1
    • Once the glue is dry, insert the screws.
  7. How to Reattach a Broken Table Leg: 手順 7、 3の画像 1 How to Reattach a Broken Table Leg: 手順 7、 3の画像 2 How to Reattach a Broken Table Leg: 手順 7、 3の画像 3
    • Use an electric drill or a screwdriver to tighten the screws.
  8. How to Reattach a Broken Table Leg: 手順 8、 1の画像 1
    • Use a paper towel to remove extra glue stains.
    • Allow the table to dry for 24 hours before turning the table.
  9. How to Reattach a Broken Table Leg: 手順 9、 2の画像 1 How to Reattach a Broken Table Leg: 手順 9、 2の画像 2
    • After 24 hours, carefully return the table to the original position.
    • Depending on the size of the table, you might need some assistance to turn the table.
終わりに
Repeat these steps to fix any other broken legs on the table.
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Kunpriya Aggarwal
メンバー登録日: 01/17/21
246 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G15, Woodhouse Winter 2021 York University, Team S1-G15, Woodhouse Winter 2021人のメンバー
YORK-WOODHOUSE-W21S1G15
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 51
過去 30 日: 220
今までの合計 9,601
