メインコンテンツにスキップ
How to Open the Fitbit Charge 2
必要な工具と部品
  1. How to Open the Fitbit Charge 2, Remove the watch band: 手順 1、 1の画像 1
    • Before starting, take your Fitbit Charge 2 off the charger and power it down.
    • Remove the watch band on both sides.
  2. How to Open the Fitbit Charge 2, Heat the touch screen: 手順 2、 1の画像 1
    • Heat an iOpener and apply it to the touch screen for two minutes.
    • The screen is not glued down, but the heat helps to loosen the touch screen assemly.
  3. How to Open the Fitbit Charge 2, Slide along the left edge: 手順 3、 3の画像 1 How to Open the Fitbit Charge 2, Slide along the left edge: 手順 3、 3の画像 2 How to Open the Fitbit Charge 2, Slide along the left edge: 手順 3、 3の画像 3
    この手順で使用する道具:
    iSesamo Opening Tool
    $9.99
    • Insert an iSesamo into the gap between the touch screen and the watch assembly on the top left corner.
    • Slide the iSesamo along the left edge to the bottom left corner.
  4. How to Open the Fitbit Charge 2, Slide along the bottom edge: 手順 4、 2の画像 1 How to Open the Fitbit Charge 2, Slide along the bottom edge: 手順 4、 2の画像 2
    • Slide the iSesamo around the bottom left corner.
    • Slide it along the edge to the bottom right corner.
  5. How to Open the Fitbit Charge 2: 手順 5、 3の画像 1 How to Open the Fitbit Charge 2: 手順 5、 3の画像 2 How to Open the Fitbit Charge 2: 手順 5、 3の画像 3
    • Slide the iSesamo around the bottom right corner.
    • Keep sliding it along the right edge to the top right corner.
  6. How to Open the Fitbit Charge 2: 手順 6、 2の画像 1 How to Open the Fitbit Charge 2: 手順 6、 2の画像 2
    • Slide the iSesamo around the top right corner.
    • Slide it along the top edge to the top left corner.
  7. How to Open the Fitbit Charge 2: 手順 7、 2の画像 1 How to Open the Fitbit Charge 2: 手順 7、 2の画像 2
    • Place the iSesamo under the top left corner.
    • Feel free to reattach the watch band for this and the next step for a better grip.
    • Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap and unhinge the plastic clips which are holding the screen in place.
  8. How to Open the Fitbit Charge 2: 手順 8、 2の画像 1 How to Open the Fitbit Charge 2: 手順 8、 2の画像 2
    • Place the iSesamo under the top right corner.
    • Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap.
  9. How to Open the Fitbit Charge 2: 手順 9、 2の画像 1 How to Open the Fitbit Charge 2: 手順 9、 2の画像 2
    • Insert a spudger into the gap on the top edge of your Fitbit Charge 2.
    • Use the spudger to pry up the touch screen assembly.
    • Do not remove the touch screen assembly all the way yet—it's still connected to the motherboard.
  10. How to Open the Fitbit Charge 2: 手順 10、 1の画像 1
    • Carefully fold the touch screen assembly in the direction of the bottom edge.
終わりに
Opening didn’t go as planned? Ask our Answers community for help.
作成者
1人の作成者と共同作成されました。
Adriana Zwink
メンバー登録日: 12/18/19
56,615 ポイント
167のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,623のガイドは作成済み
1 Guide Comment
How do I get the daughterboard out?
Pospesel - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 17
過去 30 日: 73
今までの合計 5,921
