メインコンテンツにスキップ
How to Open the Fitbit Charge 2
必要な工具と部品
  1. How to Open the Fitbit Charge 2, Remove the watch band: 手順 1、 1の画像 1
    • Before starting, take your Fitbit Charge 2 off the charger and power it down.
    • Remove the watch band on both sides.
  2. How to Open the Fitbit Charge 2, Heat the touch screen: 手順 2、 1の画像 1
    • Heat an iOpener and apply it to the touch screen for two minutes.
    • The screen is not glued down, but the heat helps to loosen the touch screen assembly from your watch.
  3. How to Open the Fitbit Charge 2, Slide along the left edge: 手順 3、 3の画像 1 How to Open the Fitbit Charge 2, Slide along the left edge: 手順 3、 3の画像 2 How to Open the Fitbit Charge 2, Slide along the left edge: 手順 3、 3の画像 3
    この手順で使用する道具:
    iSesamo Opening Tool
    $9.99
    • Insert an iSesamo into the gap between the touch screen and the watch assembly on the top left corner.
    • Slide the iSesamo along the left edge to the bottom left corner.
  4. How to Open the Fitbit Charge 2, Slide along the bottom edge: 手順 4、 2の画像 1 How to Open the Fitbit Charge 2, Slide along the bottom edge: 手順 4、 2の画像 2
    • Slide the iSesamo around the bottom left corner.
    • Slide it along the edge to the bottom right corner.
  5. How to Open the Fitbit Charge 2: 手順 5、 3の画像 1 How to Open the Fitbit Charge 2: 手順 5、 3の画像 2 How to Open the Fitbit Charge 2: 手順 5、 3の画像 3
    • Slide the iSesamo around the bottom right corner.
    • Keep sliding it along the right edge to the top right corner.
  6. How to Open the Fitbit Charge 2: 手順 6、 2の画像 1 How to Open the Fitbit Charge 2: 手順 6、 2の画像 2
    • Slide the iSesamo around the top right corner.
    • Slide it along the top edge to the top left corner.
  7. How to Open the Fitbit Charge 2: 手順 7、 2の画像 1 How to Open the Fitbit Charge 2: 手順 7、 2の画像 2
    • Place the iSesamo under the top left corner.
    • Feel free to reattach the watch band for this and the next step for a better grip.
    • Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap and unhinge the plastic clips which are holding the screen in place.
  8. How to Open the Fitbit Charge 2: 手順 8、 2の画像 1 How to Open the Fitbit Charge 2: 手順 8、 2の画像 2
    • Place the iSesamo under the top right corner.
    • Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap.
  9. How to Open the Fitbit Charge 2: 手順 9、 2の画像 1 How to Open the Fitbit Charge 2: 手順 9、 2の画像 2
    • Insert a spudger into the gap on the top edge of your Fitbit Charge 2.
    • Use the spudger to pry up the touch screen assembly.
    • Do not remove the touch screen assembly all the way yet—it's still connected to the motherboard.
  10. How to Open the Fitbit Charge 2: 手順 10、 1の画像 1
    • Carefully fold the touch screen assembly in the direction of the bottom edge.
終わりに
Opening didn’t go as planned? Ask our Answers community for help.
作成者
2人の作成者と共同で作成されました。
Adriana Zwink
メンバー登録日: 12/18/19
62,569 ポイント
167のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,788のガイドは作成済み
1件のガイドコメント
How do I get the daughterboard out?
Pospesel - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 46
今までの合計 6,489
