メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to Fix an Overheating Desktop Computer
必要な工具と部品
  1. How to Fix an Overheating Desktop Computer, How to Fix an Overheating Desktop Computer: 手順 1、 3の画像 1 How to Fix an Overheating Desktop Computer, How to Fix an Overheating Desktop Computer: 手順 1、 3の画像 2 How to Fix an Overheating Desktop Computer, How to Fix an Overheating Desktop Computer: 手順 1、 3の画像 3
    • Remove the screws from the side tempered glass panel using your hands.
    • Remove the front panel cover by applying a pulling force to the grip.
    • The position of the grip varies in case designs.
    FixBotに聞いてみる
    コメントを追加
  2. How to Fix an Overheating Desktop Computer: 手順 2、 1の画像 1
    • Clean the front panel dust filter using a tissue or a cloth.
    • This step assures the internal components can easily access fresh air without dust accretion.
    FixBotに聞いてみる
    コメントを追加
  3. How to Fix an Overheating Desktop Computer: 手順 3、 3の画像 1 How to Fix an Overheating Desktop Computer: 手順 3、 3の画像 2 How to Fix an Overheating Desktop Computer: 手順 3、 3の画像 3
    • Remove the screws that are connecting the CPU cooler and wires to the motherboard.
    • This applies to most AMD and Intel CPU brackets.
    • If you are still not sure about how to remove the cooler, refer to your motherboard’s manual guide for more information.
    FixBotに聞いてみる
    コメントを追加
  4. How to Fix an Overheating Desktop Computer: 手順 4、 1の画像 1
    • Remove the CPU from the motherboard by raising the retention arm. Lay the CPU carefully on a soft surface to avoid damaging him by deforming some pins.
    FixBotに聞いてみる
    コメントを追加
  5. How to Fix an Overheating Desktop Computer: 手順 5、 2の画像 1 How to Fix an Overheating Desktop Computer: 手順 5、 2の画像 2
    • Use a tissue to gently clean off the leftover thermal compound.
    • Apply a small amount of thermal paste (or liquid metal) to the surface of the CPU.
    • You can refer to the 放熱グリスの塗布方法 guide for more information.
    FixBotに聞いてみる
    コメントを追加
  6. How to Fix an Overheating Desktop Computer: 手順 6、 3の画像 1 How to Fix an Overheating Desktop Computer: 手順 6、 3の画像 2 How to Fix an Overheating Desktop Computer: 手順 6、 3の画像 3
    • Reattach the screws that connect the CPU cooler and wires to the motherboard.
    FixBotに聞いてみる
    コメントを追加
  7. How to Fix an Overheating Desktop Computer: 手順 7、 3の画像 1 How to Fix an Overheating Desktop Computer: 手順 7、 3の画像 2 How to Fix an Overheating Desktop Computer: 手順 7、 3の画像 3
    • Mount two 120 mm type case fans on top of the case as an addition to exhausting hot air. You need at least four screws (two for each fan mounting diagonally) to mount the fans. (I recommend eight screws.)
    • This process improves the airflow inside the case because the heat generated by the CPU and the GPU will dissipate faster.
    FixBotに聞いてみる
    コメントを追加
  8. How to Fix an Overheating Desktop Computer: 手順 8、 1の画像 1
    • Replace the screws from the side tempered glass panel using your hands.
    • Reattach the front panel cover.
    FixBotに聞いてみる
    コメントを追加
  9. How to Fix an Overheating Desktop Computer: 手順 9、 2の画像 1 How to Fix an Overheating Desktop Computer: 手順 9、 2の画像 2
    • Run the system and check for its cooling performance. When your system is on heavy workload, you can increase the fan speed of either the CPU or GPU for better heat dissipation.
    • Check the temperature of your CPU and increase the cooler fan speed by using SpeedFan.
    • Check your GPU temperature and increase the fan speed by using MSI Afterburner.
    FixBotに聞いてみる
    コメントを追加
ゴール
キャンセル: このガイドを終了できませんでした。
6 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Quan Nguyen
メンバー登録日: 05/11/20
304 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G21, O'Regan Summer 2020 York University, Team S1-G21, O'Regan Summer 2020人のメンバー
YORK-O'REGAN-SU20S1G21
1 メンバー
3のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 58
今までの合計 5,652
