メインコンテンツにスキップ
How to Clean Stains On A Baking Sheet
必要な工具と部品
  1. How to Clean Stains On A Baking Sheet, How to Clean Stains On A Baking Sheet: 手順 1、 1の画像 1
    • Place the dirty baking sheet on a flat surface.
    • Tip: This method can be used on stained pots and pans as well.
    • Tip: This method works best if you clean the stained baking sheet as soon as it has cooled after use.
    • Note: The liquid on the baking sheet is grease. This method will work whether or not there is grease on the baking sheet
  2. How to Clean Stains On A Baking Sheet: 手順 2、 2の画像 1 How to Clean Stains On A Baking Sheet: 手順 2、 2の画像 2
    • Cover the stained part of the baking sheet with a thin layer of baking soda.
  3. How to Clean Stains On A Baking Sheet: 手順 3、 2の画像 1 How to Clean Stains On A Baking Sheet: 手順 3、 2の画像 2
    • Pour a small amount of water over the baking soda so the baking soda looks pasty.
    • Tip: Do not put too much water on the baking soda, as it will cause the baking soda to spread and not stay on the desired cleaning area.
  4. How to Clean Stains On A Baking Sheet: 手順 4、 1の画像 1
    • Set a timer for 15 minutes, press start, and wait until timer goes off.
  5. How to Clean Stains On A Baking Sheet: 手順 5、 2の画像 1 How to Clean Stains On A Baking Sheet: 手順 5、 2の画像 2
    • Take a sponge and clean the desired area.
    • Tip: If the baking soda becomes too thick when scrubbing, add more water.
    • Tip: Using the rough side of the sponge makes cleaning easier.
  6. How to Clean Stains On A Baking Sheet: 手順 6、 3の画像 1 How to Clean Stains On A Baking Sheet: 手順 6、 3の画像 2 How to Clean Stains On A Baking Sheet: 手順 6、 3の画像 3
    • Rinse off the baking soda and wash the baking sheet again with soap and water.
    That looks like a teflon coated baking sheet? I would not recommend using a green (coarse ) scotchbrite pad on a teflon coated surface as you will damage the coating!
    I. Margaronis - 返信
終わりに
Congratulations! You have a baking sheet that looks good as new.
31 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Ashlee Takushi
メンバー登録日: 02/24/15
1,129 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 23-5, Green Winter 2015 Cal Poly, Team 23-5, Green Winter 2015人のメンバー
CPSU-GREEN-W15S23G5
4 メンバー
9のガイドは作成済み
3件のガイドコメント
I’ve also had good success getting stains off stainless steel following a similar process but using cream of tartar + vinegar instead of baking soda + water. Cream of tartar with vinegar forms an acidic paste instead of the alkaline paste of the baking soda. Of course, don’t mix these approaches or expect unhelpful frothiness.
Don - 返信
Don, thanks for the additional tips, especially the acidic versus alkaline aspects.
Mike Rehbein -
is that a non stick baking sheet? How is it on steel?
Christine Shriam - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 16
過去 30 日: 108
今までの合計 8,975
