メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to Clean Corroded Battery Terminals
必要な工具と部品
    1. How to Clean Corroded Battery Terminals, Safety precautions: 手順 1、 1の画像 1
      • Wear gloves to protect your hands from the corrosion—it's a skin irritant.
      • If your device still works, power it down completely before starting.
      FixBotに聞いてみる
      コメントを追加
    2. How to Clean Corroded Battery Terminals, Remove the batteries: 手順 2、 3の画像 1 How to Clean Corroded Battery Terminals, Remove the batteries: 手順 2、 3の画像 2 How to Clean Corroded Battery Terminals, Remove the batteries: 手順 2、 3の画像 3
      • Remove the batteries from your device.
      • If there's a lot of corrosion, the batteries may be stuck in their recess. Don't try to force them out...unless you're a small, green, force-sensitive creature.
      • If any batteries are stuck, follow the next step as normal to clean around them.
      FixBotに聞いてみる
      コメントを追加
    3. How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: 手順 3、 3の画像 1 How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: 手順 3、 3の画像 2 How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: 手順 3、 3の画像 3
      この手順で使用する道具:
      Anti-Static Brush
      $2.99
      • Use a toothbrush or anti‑static brush to gently remove any bigger chunks of corrosion from the battery terminals and battery recess.
      • Use the point of a spudger to pick out any bits that are stuck.
      • Pick around the batteries, and not at the batteries themselves.
      • Flip your device over and gently shake out the loose corrosion and debris.
      • Dispose of the corrosion and debris in the trash.
      FixBotに聞いてみる
      コメントを追加
    4. How to Clean Corroded Battery Terminals, Remove any stuck batteries: 手順 4、 2の画像 1 How to Clean Corroded Battery Terminals, Remove any stuck batteries: 手順 4、 2の画像 2
      • You should now be able to remove any batteries that were previously stuck.
      • Clean out the battery recess with a toothbrush.
      FixBotに聞いてみる
      コメントを追加
    5. How to Clean Corroded Battery Terminals, Clean the terminals: 手順 5、 3の画像 1 How to Clean Corroded Battery Terminals, Clean the terminals: 手順 5、 3の画像 2 How to Clean Corroded Battery Terminals, Clean the terminals: 手順 5、 3の画像 3
      • Alkaline batteries contain a base, which is what corrosion is made of. An acid like white vinegar or lemon juice will neutralize this base.
      • Lightly dip a cotton swab in white vinegar or lemon juice.
      • Don't soak the cotton swab. Only use a small amount of liquid at a time.
      • Gently rub the battery terminals with the cotton swab to dissolve and remove the corrosion.
      • The corrosion may fizz and bubble. Don't worry, this is normal.
      • Continue this process until there's no corrosion on the terminals.
      FixBotに聞いてみる
      コメントを追加
    6. How to Clean Corroded Battery Terminals: 手順 6、 3の画像 1 How to Clean Corroded Battery Terminals: 手順 6、 3の画像 2 How to Clean Corroded Battery Terminals: 手順 6、 3の画像 3
      この手順で使用する道具:
      Microfiber Cleaning Cloths
      $3.99
      • Isopropyl alcohol will remove any residue left from the previous step.
      • Lightly dip a cotton swab in highly-concentrated isopropyl alcohol (over 90%).
      • Gently rub the battery terminals with the cotton swap to remove any remaining residue from the previous step.
      • Wipe the residue away with a microfiber or lint-free cloth.
      • Repeat this process until the terminals are completely clean.
      • Wait two minutes to allow any residual alcohol to evaporate.
      FixBotに聞いてみる
      コメントを追加
    7. How to Clean Corroded Battery Terminals, Install new batteries: 手順 7、 3の画像 1 How to Clean Corroded Battery Terminals, Install new batteries: 手順 7、 3の画像 2 How to Clean Corroded Battery Terminals, Install new batteries: 手順 7、 3の画像 3
      FixBotに聞いてみる
      コメントを追加
終わりに
Cleaning didn’t go as planned? Ask our Answers community for help.
For other electronics skills, click here.
キャンセル: このガイドを終了できませんでした。
21 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Spencer Day
メンバー登録日: 09/14/22
199,958 ポイント
1,243のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
80,911のガイドは作成済み
2件のガイドコメント
Good article, thanks.
MarkDownUnder - 返信 共有
Nice Article . Thanks Bro
TSM Tool - 返信 共有
コメントを追加
統計データ:
過去 24時間: 61
過去 7 日: 476
過去 30 日: 2,137
今までの合計 72,506
