メインコンテンツにスキップ
How to Apply the Power Button Board Adhesive in your Kobo Clara eReader
必要な工具と部品
  1. How to Apply the Power Button Board Adhesive in your Kobo Clara eReader, Remove the old adhesive: 手順 1、 1の画像 1
    この手順で使用する道具:
    購入する
    • If you're transferring your power button board to a new screen, follow the next three steps. Otherwise, skip to this step to install a new power button board.
    • Use tweezers, or your fingers, to remove any remaining adhesive on the bottom of your power button board.
    • Make sure the board is as clean as possible so the replacement adhesive sits evenly on the frame.
  2. How to Apply the Power Button Board Adhesive in your Kobo Clara eReader, Apply the adhesive: 手順 2、 3の画像 1 How to Apply the Power Button Board Adhesive in your Kobo Clara eReader, Apply the adhesive: 手順 2、 3の画像 2 How to Apply the Power Button Board Adhesive in your Kobo Clara eReader, Apply the adhesive: 手順 2、 3の画像 3
    この手順で使用する道具:
    Tesa 61395 Tape
    $2.99
    購入する
    • Measure and cut a few strips of a thin double-sided tape, like Tesa tape, and apply it to the bottom of the power button board.
    • Peel off the liners from the strips to expose the adhesive.
  3. How to Apply the Power Button Board Adhesive in your Kobo Clara eReader, Secure the power button board: 手順 3、 2の画像 1 How to Apply the Power Button Board Adhesive in your Kobo Clara eReader, Secure the power button board: 手順 3、 2の画像 2
    • Place the power button board on its spot on the frame, making sure it's aligned with its two pegs.
    • Press down on the power button board to adhere it.
  4. How to Apply the Power Button Board Adhesive in your Kobo Clara eReader, Remove the old adhesive: 手順 4、 2の画像 1 How to Apply the Power Button Board Adhesive in your Kobo Clara eReader, Remove the old adhesive: 手順 4、 2の画像 2
    • Use a spudger, or your fingers, to remove the remaining adhesive at the power button board's spot on the frame.
    • Apply a few drops of isopropyl alcohol (>90%) to the power button board's spot on the frame.
    • Use a coffee filter or a lint-free cloth to wipe off any remaining adhesive residue.
    • Make sure the spot is as clean as possible so the replacement adhesive sits evenly on the frame.
  5. How to Apply the Power Button Board Adhesive in your Kobo Clara eReader, Secure the power button board: 手順 5、 3の画像 1 How to Apply the Power Button Board Adhesive in your Kobo Clara eReader, Secure the power button board: 手順 5、 3の画像 2 How to Apply the Power Button Board Adhesive in your Kobo Clara eReader, Secure the power button board: 手順 5、 3の画像 3
    • Peel off the liner on the bottom of the new power button board to expose the adhesive.
    • Place the power button board on its spot on the frame, making its aligned with its two pegs.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
作成者
3人の作成者と共同で作成されました。
Alex Diaz-Kokaisl
メンバー登録日: 01/16/22
129,318 ポイント
600のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
140 メンバー
18,067のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 24
今までの合計 176
