はじめに
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to replace the outer screen adhesive in your Google Pixel Fold following a repair.
Follow this guide to remove the outer screen, if you haven't done so already.
必要な工具と部品
Peel off the new small top right adhesive strip from its clear liner.
Place the new adhesive on the top right bracket of the frame.
Use a spudger, or your fingers, to press down the adhesive to adhere it.
Before removing any liners, check if the large perimeter adhesive matches the frame.
Look for cutouts in the liner to help orient the adhesive.
Peel off the new adhesive strip from its clear liner.
Align the adhesive over the frame, starting with the top left and bottom left edges.
Place the adhesive over the perimeter of the frame.
Peel up the segmented tab at the bottom left corner of the large blue liner.
Lift the tab and peel off the large blue liner to expose the secondary liner.
Support the screen with your hand or prop it up on something sturdy.
Reconnect the screen cable.
Reconnect the flip battery cable.
Use a Torx Plus 3IP driver to refasten the bottom bracket.
Use tweezers, or your fingers, to peel up either one of the tabs at the top right corner of the secondary liner.
Lift the tab and peel off the secondary liner to expose the top adhesive.
Align the screen over its cutout in the frame.
Place a right edge of the screen on the frame, making sure there are no gaps or jutting adhesive.
Place the left edge of the screen on the frame.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel Fold Answers Community for help.
