メインコンテンツにスキップ
How to Apply New Base Battery Adhesive in Your Google Pixel Fold
必要な工具と部品
  1. How to Apply New Base Battery Adhesive in Your Google Pixel Fold, Remove the old adhesive: 手順 1、 3の画像 1 How to Apply New Base Battery Adhesive in Your Google Pixel Fold, Remove the old adhesive: 手順 1、 3の画像 2 How to Apply New Base Battery Adhesive in Your Google Pixel Fold, Remove the old adhesive: 手順 1、 3の画像 3
    この手順で使用する道具:
    Microfiber Cleaning Cloths
    $3.99
    • Apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the old adhesive.
    • Use the flat end of a spudger and tweezers to remove the remaining adhesive from the frame.
    • Wipe any remaining isopropyl alcohol residue with a lint-free or microfiber cloth.
  2. How to Apply New Base Battery Adhesive in Your Google Pixel Fold, Align the adhesive: 手順 2、 3の画像 1 How to Apply New Base Battery Adhesive in Your Google Pixel Fold, Align the adhesive: 手順 2、 3の画像 2 How to Apply New Base Battery Adhesive in Your Google Pixel Fold, Align the adhesive: 手順 2、 3の画像 3
    • Place the new adhesive strips over the frame to check their proper orientation.
    • Although there are multiple strips, they come attached to a single blue liner.
    • The clear liner should face the frame.
    • Use the white lines on the frame to align the adhesive strip bottom left corners.
  3. How to Apply New Base Battery Adhesive in Your Google Pixel Fold, Apply the adhesive: 手順 3、 3の画像 1 How to Apply New Base Battery Adhesive in Your Google Pixel Fold, Apply the adhesive: 手順 3、 3の画像 2 How to Apply New Base Battery Adhesive in Your Google Pixel Fold, Apply the adhesive: 手順 3、 3の画像 3
    • Be careful during this step, as it's easy to stick the adhesive in the wrong spot. Take your time and work slowly.
    • Peel off the new adhesive strip from its clear liner and apply the sticky side to the frame.
  4. How to Apply New Base Battery Adhesive in Your Google Pixel Fold: 手順 4、 3の画像 1 How to Apply New Base Battery Adhesive in Your Google Pixel Fold: 手順 4、 3の画像 2 How to Apply New Base Battery Adhesive in Your Google Pixel Fold: 手順 4、 3の画像 3
    • Use a spudger, or your fingers, to press down the adhesive and adhere it to the frame.
    • Grip the pull tab and peel off the blue liner to expose the top adhesive.
  5. How to Apply New Base Battery Adhesive in Your Google Pixel Fold, Secure the battery: 手順 5、 3の画像 1 How to Apply New Base Battery Adhesive in Your Google Pixel Fold, Secure the battery: 手順 5、 3の画像 2 How to Apply New Base Battery Adhesive in Your Google Pixel Fold, Secure the battery: 手順 5、 3の画像 3
    • Depending on your repair, your logic board might be removed. Be careful when aligning the battery to ensure the cable reaches the logic board properly.
    • If your battery pull tabs are still intact, you can thread them under the battery. Use tape with light adhesive to stick them in their original position.
    • If you have your logic board installed, reconnect the battery connector temporarily to ensure the battery gets aligned properly.
    • Place the battery in its recess, making sure to align it as close to the top edge of the recess lip as possible.
    • Press down on the battery to adhere it to the frame.
    • Make sure the battery is disconnected before continuing your repair.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel Fold Answers Community for help.
作成者
1人の作成者と共同作成されました。
Alex Diaz-Kokaisl
メンバー登録日: 01/16/22
213,338 ポイント
1,040のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,638のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 17
今までの合計 234
