メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to Apply Flash Unit Adhesives in Your Google Pixel 8a
必要な工具と部品
  1. How to Apply Flash Unit Adhesives in Your Google Pixel 8a, Apply the logic board cover adhesive: 手順 1、 3の画像 1 How to Apply Flash Unit Adhesives in Your Google Pixel 8a, Apply the logic board cover adhesive: 手順 1、 3の画像 2 How to Apply Flash Unit Adhesives in Your Google Pixel 8a, Apply the logic board cover adhesive: 手順 1、 3の画像 3
    • Use tweezers to remove the conductive tape adhesive from the top right corner of the motherboard cover.
    • Use the flat end of a spudger to scrape up any remaining bits of adhesive.
    • Use a pipette or syringe to apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the adhesive residue and wipe it away with a microfiber cloth.
    FixBotに聞いてみる
    コメントを追加
  2. How to Apply Flash Unit Adhesives in Your Google Pixel 8a: 手順 2、 3の画像 1 How to Apply Flash Unit Adhesives in Your Google Pixel 8a: 手順 2、 3の画像 2 How to Apply Flash Unit Adhesives in Your Google Pixel 8a: 手順 2、 3の画像 3
    • Remove the conductive tape adhesive from its larger clear backing and put it into place with the tab on the right.
    • Use the flat end of a spudger to press down and secure the conductive tape.
    • Remove the remaining liner.
    FixBotに聞いてみる
    コメントを追加
  3. How to Apply Flash Unit Adhesives in Your Google Pixel 8a, Apply the flash unit adhesive: 手順 3、 2の画像 1 How to Apply Flash Unit Adhesives in Your Google Pixel 8a, Apply the flash unit adhesive: 手順 3、 2の画像 2
    • Check the condition of the adhesive on the bottom of the flash unit.
    • If the adhesive is undamaged and still sticky, you can skip the rest of this guide and return to your original repair guide.
    • If the adhesive is damaged or no longer sticky, follow the next three steps to replace it.
    FixBotに聞いてみる
    コメントを追加
  4. How to Apply Flash Unit Adhesives in Your Google Pixel 8a: 手順 4、 3の画像 1 How to Apply Flash Unit Adhesives in Your Google Pixel 8a: 手順 4、 3の画像 2 How to Apply Flash Unit Adhesives in Your Google Pixel 8a: 手順 4、 3の画像 3
    • During the remaining steps, be very careful not to strain or tear the delicate flash unit cable.
    • Use a spudger and tweezers to carefully scrape up and remove the old adhesive from the bottom of the flash unit.
    FixBotに聞いてみる
    コメントを追加
  5. How to Apply Flash Unit Adhesives in Your Google Pixel 8a: 手順 5、 3の画像 1 How to Apply Flash Unit Adhesives in Your Google Pixel 8a: 手順 5、 3の画像 2 How to Apply Flash Unit Adhesives in Your Google Pixel 8a: 手順 5、 3の画像 3
    • Remove the flash unit adhesive from its larger, clear liner and put it into place on the bottom of the flash unit.
    • Use the flat end of a spudger to press down and secure the adhesive.
    FixBotに聞いてみる
    コメントを追加
  6. How to Apply Flash Unit Adhesives in Your Google Pixel 8a: 手順 6、 1の画像 1
    • Firmly press the flash unit into place on the logic board cover to secure it with the adhesive.
    • Return to your original guide and continue with reassembly.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Spencer Day
メンバー登録日: 09/14/22
189,369 ポイント
1,190のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
122 メンバー
25,844のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 24
過去 30 日: 78
今までの合計 840
