メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How jump start a Car or Truck
閲覧: 6195
統計データ:
過去24時間:
11
過去7日:
81
過去30日:
442
今までの合計
6,195
コメント: 1
手順に関する1件のコメント.
完了済み: 7
7人のユーザーがこのガイドを「完了」させました。あなたも加わりませんか?
お気に入り: 0
誰もこのガイドをお気に入りに登録していません。一番最初の登録者になりませんか?
所要時間: 5 - 10 分
難易度: 簡単
コミュニティメンバーによる寄稿ガイド
iFixitコミュニティーの素晴らしいメンバーがこのガイドを作成しました。iFixitスタッフによって作成されたものではありません。
はじめに
手順 1 に進む ↓
Jump starting is a way to start a car with a dead battery by using another vehicle's battery to provide power. This is done by connecting the dead battery to the other vehicle's battery using jumper cables. The other vehicle's battery provides power to the dead battery, allowing the car to start.
Jump starting electric cars
Electric vehicles are also equipped with a 12-volt starter battery to activate the high-voltage system. Empty or defective starter batteries are therefore also possible in this vehicle category. The jump start basically works the same as with any petrol or diesel engine.
Jump starting is generally allowed for electric cars, but using them to jump start another car is usually not permitted by the manufacturer. Electric vehicles are normally equipped with smaller starter batteries. For this reason, in the worst case, an electric car that provides power for a jump start could damage the donor battery or the on-board electrical systems.
Warning
It is important to follow the proper procedure when jump starting a car to avoid damaging the vehicles or causing harm to yourself.
必要な工具と部品
ツール
    1. FixBotに聞いてみる
      コメントを追加
    2. How jump start a Car or Truck, Unlock the hood: 手順 2、 1の画像 1
      • Pull the hood release lever. It's usually located inside the car, near the steering column.
      • If you can't find the release lever in your car, it might help to consult the car's owner's manual.
      FixBotに聞いてみる
      コメントを追加
    3. How jump start a Car or Truck, Open the hood: 手順 3、 1の画像 1
      • Raise the hood by simultaneously lifting and pressing the hood latch release. It is usually a paddle located beneath the front edge of the hood, near the center or center-right.
      FixBotに聞いてみる
      コメントを追加
    4. How jump start a Car or Truck, Secure the hood: 手順 4、 2の画像 1 How jump start a Car or Truck, Secure the hood: 手順 4、 2の画像 2
      • At this point, depending on the vehicle, your hood may raise and support itself automatically, if not, use one hand to hold the hood open temporarily while securing the hood with the prop rod.
      • Lift one end of the prop rod up or out to release it from the front area of the engine bay.
      • Swing the end of the prop rod up and slide it into the corresponding cutout on the underside of the hood.
      • Make sure the hood is well secured before you let go with your other hand, or it may fall and injure you.
      FixBotに聞いてみる
      コメントを追加
    5. How jump start a Car or Truck, Locate the battery: 手順 5、 1の画像 1
      • Locate the battery on both cars.
      • The battery might be hidden under a cover. Usually, you can just look for a car battery-sized plastic cover with a battery pictogram on it.
      FixBotに聞いてみる
      コメントを追加
    6. How jump start a Car or Truck, Connect the red wire: 手順 6、 1の画像 1
      • Connect the red wire to the + lead of the battery in the donor car.
      • Then connect the other end of the red wire to the + lead of the dead battery.
      • The + lead is typically covered by a plastic cover. If both leads are covered the + lead is usually red.
      • If you mix up the + and - poles when starting the vehicle, you risk expensive damage to the vehicle's electrical system.
      FixBotに聞いてみる
      コメントを追加
    7. How jump start a Car or Truck, Connect the black wire: 手順 7、 1の画像 1
      • Connect the black wire to the - lead on the donor cars battery.
      FixBotに聞いてみる
      コメントを追加
    8. How jump start a Car or Truck, Connect the black wire: 手順 8、 1の画像 1
      • Connect the other end of the black wire to the ground connection/ground point or a metal part of the motor block of the broken-down car.
      • You can typically find the ground connection/ground point written in your car’s manual.
      • Do not connect the black wire directly to the - terminal of the dead battery. Doing so may create sparks near the battery, potentially causing an explosion.
      FixBotに聞いてみる
      コメントを追加
      • Start the motor of the donor car.
      FixBotに聞いてみる
      コメントを追加
      • After a couple of minutes, try to start the broken-down car.
      • If it doesn’t work, try again a minute later.
      • After the third unsuccessful attempt to start the car, further attempts may cause damage. Consider seeking professional assistance.
      FixBotに聞いてみる
      コメントを追加
      • If the broken-down car has succeeded in starting, let both vehicles run for a few more minutes.
      FixBotに聞いてみる
      コメントを追加
      • When the engine is running in the recipient car, switch on larger, power hungry electric loads, such as the AC, radio and lights to avoid voltage peaks and thus protect the on-board electronics.
      FixBotに聞いてみる
      コメントを追加
      • First disconnect the black wire from the donor car, then from the broken-down car.
      • Remove the red wire last.
      FixBotに聞いてみる
      コメントを追加
      • Keep the broken-down car’s engine running and switch off the unneeded electronics again.
      FixBotに聞いてみる
      コメントを追加
      • Watch out for any warning lights on the dash and call a professional if any problems occur.
      • In the event of problems occurring, the electrical support for driving functions such as power steering can fail.
      FixBotに聞いてみる
      コメントを追加
終わりに
Drive safe and don’t forget to recharge or replace your battery!
キャンセル: このガイドを終了できませんでした。
7 の人々がこのガイドを完成させました。
作成者
と共同で作成されました。
Sebastian
メンバー登録日: 08/19/18
33,910 ポイント
72のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 81
過去 30 日: 442
今までの合計 6,195
