メインコンテンツにスキップ
How To Replace the Battery on a Conair Trimmer (GMT15NCS)
必要な工具と部品
  1. How To Replace the Battery on a Conair Trimmer (GMT15NCS), Conair Trimmer (GMT15NCS) Battery Replacement: 手順 1、 3の画像 1 How To Replace the Battery on a Conair Trimmer (GMT15NCS), Conair Trimmer (GMT15NCS) Battery Replacement: 手順 1、 3の画像 2 How To Replace the Battery on a Conair Trimmer (GMT15NCS), Conair Trimmer (GMT15NCS) Battery Replacement: 手順 1、 3の画像 3
    • Using a Phillips #0 screwdriver, remove the two screws holding the trimmer blade in place.
    • Hold down the trimmer blades to make it easier to remove the screws.
  2. How To Replace the Battery on a Conair Trimmer (GMT15NCS): 手順 2、 2の画像 1 How To Replace the Battery on a Conair Trimmer (GMT15NCS): 手順 2、 2の画像 2
    • Lift both of the trimmer blades off of the plastic guard.
  3. How To Replace the Battery on a Conair Trimmer (GMT15NCS): 手順 3、 3の画像 1 How To Replace the Battery on a Conair Trimmer (GMT15NCS): 手順 3、 3の画像 2 How To Replace the Battery on a Conair Trimmer (GMT15NCS): 手順 3、 3の画像 3
    • Separate the plastic guard from the casing by using the metal spudger tool.
    • Pry up at the top of the plastic guard, NOT the bottom.
  4. How To Replace the Battery on a Conair Trimmer (GMT15NCS): 手順 4、 2の画像 1 How To Replace the Battery on a Conair Trimmer (GMT15NCS): 手順 4、 2の画像 2
    • Using a Phillips #000 screwdriver, remove the two screws inside the casing.
    • Tilt the trimmer to prevent the screws from falling into the casing.
  5. How To Replace the Battery on a Conair Trimmer (GMT15NCS): 手順 5、 1の画像 1
    • Using a Phillips #000 screwdriver, remove the casing screw at the bottom of the trimmer.
    • Tilt the trimmer so gravity helps the screw fall out.
  6. How To Replace the Battery on a Conair Trimmer (GMT15NCS): 手順 6、 3の画像 1 How To Replace the Battery on a Conair Trimmer (GMT15NCS): 手順 6、 3の画像 2 How To Replace the Battery on a Conair Trimmer (GMT15NCS): 手順 6、 3の画像 3
    • Fire Hazard: Be careful not to stick the metal spudger too deep when prying to avoid puncturing the battery.
    • Separate the casing at the seam using the metal spudger to release the clips.
    • Use a twisting or prying motion, in any direction, to separate the casing.
    • The same process may be needed on the other side's seam to release clips.
  7. How To Replace the Battery on a Conair Trimmer (GMT15NCS): 手順 7、 3の画像 1 How To Replace the Battery on a Conair Trimmer (GMT15NCS): 手順 7、 3の画像 2 How To Replace the Battery on a Conair Trimmer (GMT15NCS): 手順 7、 3の画像 3
    • Remove the two screws holding the battery setup in place.
    • Take note of the position of the positive and negative terminals of the battery on the setup.
  8. How To Replace the Battery on a Conair Trimmer (GMT15NCS): 手順 8、 1の画像 1
    • Lift the battery setup out of the casing.
    • Take note of how the battery setup lays in the casing.
  9. How To Replace the Battery on a Conair Trimmer (GMT15NCS): 手順 9、 3の画像 1 How To Replace the Battery on a Conair Trimmer (GMT15NCS): 手順 9、 3の画像 2 How To Replace the Battery on a Conair Trimmer (GMT15NCS): 手順 9、 3の画像 3
    • The soldering iron with be hot.
    • Using the soldering iron, desolder the battery at the connection to remove the battery from the setup.
    • Use iFixit's guide on はんだ付けとはんだ除去の作業ガイド if you are not familiar using a soldering tool.
終わりに
To reassemble your device, solder the new 2.4 V battery into the setup, and follow the instructions in reverse.
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Nicholas Ellis
メンバー登録日: 02/20/19
223 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team S2-G6, Baddour Spring 2019 University of Memphis, Team S2-G6, Baddour Spring 2019人のメンバー
UM-BADDOUR-S19S2G6
2 メンバー
1のガイドは作成済み
コメント 1 件
Where can I buy the batery
Wenceslao Hernandez - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 87
今までの合計 9,935
