メインコンテンツにスキップ
Hover-1 Eagle Throttle/Brake Lever Replacement
必要な工具と部品
  1. Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: 手順 1、 3の画像 1 Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: 手順 1、 3の画像 2 Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: 手順 1、 3の画像 3
    • Unscrew the scooter handle.
    • The scooter handles are left-handed or reverse threaded, so twist clockwise to remove them.
  2. Hover-1 Eagle Throttle/Brake Lever Replacement: 手順 2、 3の画像 1 Hover-1 Eagle Throttle/Brake Lever Replacement: 手順 2、 3の画像 2 Hover-1 Eagle Throttle/Brake Lever Replacement: 手順 2、 3の画像 3
    • Push back the fastening clips by wedging the plastic spudger between the clip and the throttle handle.
    • Insert iFixit opening picks between each fastening clip and the throttle handle to prevent re-fastening.
    • Pull the throttle lever off gently by pulling towards you.
    • The spring housed in the handle can sometimes send the lever flying. Maintain a firm grip on the throttle lever.
  3. Hover-1 Eagle Throttle/Brake Lever Replacement: 手順 3、 3の画像 1 Hover-1 Eagle Throttle/Brake Lever Replacement: 手順 3、 3の画像 2 Hover-1 Eagle Throttle/Brake Lever Replacement: 手順 3、 3の画像 3
    • To reassemble, insert the spring into the placement hole, housed inside the throttle handle. Insert the other end of the spring into the placement hole inside the throttle body housing.
  4. Hover-1 Eagle Throttle/Brake Lever Replacement: 手順 4、 3の画像 1 Hover-1 Eagle Throttle/Brake Lever Replacement: 手順 4、 3の画像 2 Hover-1 Eagle Throttle/Brake Lever Replacement: 手順 4、 3の画像 3
    • Twist the throttle lever back to its original orientation by rotating it to the left.
    • Apply pressure to the throttle handle until you hear the fastening clips take hold the of the throttle lever.
    • Make sure the throttle lever is fully inserted and flush with the display throttle body.
  5. Hover-1 Eagle Throttle/Brake Lever Replacement: 手順 5、 3の画像 1 Hover-1 Eagle Throttle/Brake Lever Replacement: 手順 5、 3の画像 2 Hover-1 Eagle Throttle/Brake Lever Replacement: 手順 5、 3の画像 3
    • Reattach the scooter handle.
    • Make sure to twist the handles counterclockwise to tighten.
ゴール
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Andrew Gaskell
メンバー登録日: 01/23/20
1,008 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team S1-G2, White Winter 2020 Cal Poly, Team S1-G2, White Winter 2020人のメンバー
CPSU-WHITE-W20S1G2
4 メンバー
6のガイドは作成済み
24 件のコメント
Great detail……….. Where can I buy the replacement part (throttle) the company hover1 isn't answering me and they don't have this part on their website. Thanks
hanjna76 - 返信
Im needed a throttle did anyone have any luck?
rodarte_amanda1992 -
Where do I buy the part where do I get it please let me know The brake lever
poorbubbaa - 返信
Necesito acelerador y no lo encuentro.
Josue Villanueva - 返信
I cant squeeze the spudger and the pick between this and the spudger broke…what the!!!
Cheri Rael - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 15
過去 30 日: 83
今までの合計 15,395
