この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will show you how to replace the LED headlights on the front of the Hover-1 Chrome. You will need a Phillips #2 screwdriver.
必要な工具と部品
Flip the Hover-1 Chrome upside down.
Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
Use a Phillips #2 screwdriver to remove the two 2 mm screws on either side of the LEDs.
Remove the LED board.
もう少しです!
終わりに
